Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 05-29-2017, 05:24   #1 (permalink)
Cheater -Don't Deal with him-
Member: 1439117
Sonork: Troykingchin
Thanks Meter: 12
Help unlock SM-G570M FRP J5 Prime
Please help team!
This tool is not removing frp lock no matter how I try.
first I flash the combination file to see if this would work it say frp remove or bypass successful and I even hard reset phone plenty times. Then I flash firmware that the tool support and it still didn't worked,
Please help.
Thanks in advanced
Old 05-29-2017, 11:20   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 24,349
reply
Dear Sir,
could you send us work id for the problematic process please?
Thank you in advance!
Best regards
Nicole
Originally Posted by Troykingchin View Post
Please help team!
Please help.
Thanks in advanced
Old 05-30-2017, 14:33   #3 (permalink)
Member: 1439117
Thanks Meter: 12
hello team! WorkID: 21783729
Old 05-30-2017, 14:46   #4 (permalink)
Member: 1787203
reply
Dear Sir,
when I see you started frp lock remove 2 process.
I can offer you try again the process just with older than august 2016 firmware or firmware with older modem.
Best regards
Nicole
Old 05-30-2017, 14:52   #5 (permalink)
Member: 1439117
Thanks Meter: 12
I did that using combination firmware. COMBINATION_UUB_FA60_G570MUBU1API3
and COMBINATION_UUB_FA60_G570MUBU1API4
and I also tried the firmware that chimera tool supported G570MUBU1AQA1.
no more firmware available for this model on any paid support I have so please if you have link to that file let me have it please.
Old 05-30-2017, 15:08   #6 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Here is a download link for Firmware for G570M
https://trueandroid.com/es/samsung-g...descarga-guia/
If you have flash with combination file, after flashing, connect the phone to chimera in NORMAL MODE and not in download mode and then do the FRP. (Reset FRP Lock - New)
Once the result is satisfactory:
1. USB port ok
2. OEM unlock ok
3. Manual deletion from the phone menu
4. Flash the phone with firmware stock
Old 05-30-2017, 15:27   #7 (permalink)
Member: 1439117
Thanks Meter: 12
I flash with combination as you said and then connect to chimera tool, did frp reset and got successful but when I flash back stock or any other firmware its still frp lock..... this is a bad phone
Old 05-30-2017, 15:48   #8 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
1. USB port ok
2. OEM unlock ok
4. Flash the phone with the last stock firmware
Old 05-30-2017, 16:10   #9 (permalink)
Member: 1439117
Thanks Meter: 12
oem unlock option not in combination. What do you mean ny usb ok?
Old 01-04-2018, 03:54   #10 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
1. USB port ok
2. OEM unlock ok
If the OEM unlock option is not available, skip this topic but be sure to do the other steps once you do the FRP with chimera being in the combination file. All these for Binary firmwares: 1
Old 01-04-2018, 03:59   #11 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
G570M with binary: 2 (Manual Test Solution)
I tried the combination file with binary: 2 and then FRP with Chimera and the negative result. Currently chimera solves for binary: 1
It was in version 7.0 binary:2
Use this Binary firmware: 2 G570MUBU2AQK2_ZTO2AQK2 version 6.0.1
I did flash and then the simple steps:
1. Connect to a Wi-Fi network
2. Go up on the right side where it says more and we give you add network
3. We write some text and press where it says assistance (You have to be in version 6.0.1)
4. We write chrome and download quickshortcutmaker and google account manager 6.1
5. We return to assistance and write my files and install the google account manager
6. We install the other application and we open and go google account manager and then go where it says enter email and password
7. They give you where it says try and leave another window and go to the 3 dots on the right side and give access to the browser and enter an account and give it a restart and ready to restart factory and ready 100% tested.
Old 01-04-2018, 04:11   #12 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Chimera Mobile Phone Utility version: 16.16.1303 @ 2018-01-04
[Read codes started]
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G570M
Sales Code: ZTO
Country Code: Brazil
Timezone: America/Argentina/Buenos_Aires
Android Version: 6.0.1 [MMB29K]
Build Date: Thu Nov 9 22:32:35 KST 2017
PDA Version: G570MUBU2AQK2 [november 2017, rev2]
Phone Version: G570MUBU2AQJ1 [october 2017, rev1]
CSC Version: G570MZTO2AQK2 [november 2017, rev2]
Product Code: SM-G570MWDVZTO
HIDSw Version: G570MUBU2AQK2/G570MZTO2AQK2/G570MUBU2AQJ1/G570MUBU2AQK2
Board Platform: EXYNOS5
Modem Platform: SHANNON305
Serial Number: R28J62VKHRH
Imei: 354621083649793
Unique Number: CQ3002E52971A54
Connections: AT,MTP
Battery Status: 4.33V (100%)
Network Type: GSM
SIM Status: ABSENT
Multisim Config: SS
Knox Version: v30
Warranty Bit: 0
Security Patch: 2017-08-01
Data Encryption State: encrypted
Reading Codes Online...
Searching serial port. Be patient! Do NOT disconnect the phone!
Serial port not found.
1. On dial window enter *#0808# 2. Select DM+ACM+ADB or DM+MODEM+ADB 3. Tap OK on phone display 4. Wait a few seconds until the diag port is up 5. Click OK button
Serial port found on COM157
Reading data. Be patient! Do NOT disconnect the phone!
Communicating with the server...
Waiting for the server to respond.
 This operation costed 59 credits.
New balance: 333
Master Lock: 90538594
Network Lock: 00000000
Subset Lock: 00000000
SP Lock: 00000000
CP Lock: 00000000
SIM Lock: 00000000
Finished successfully.
Finished at local time: [01.04.18 00:09:16]
WorkID: 31481396
Old 03-28-2018, 22:45   #13 (permalink)
Member: 110006
Thanks Meter: 19
Gathering device info...
Collecting device information. Be patient! Do NOT disconnect the phone!
Selected model: SM-G570M
DVIF
CAPA: 16
FWVER: 3
MODEL: SM-G570M
PRODUCT: Q313BB
UN: CQ300CF48C8B214
VENDOR: SAMSUNG
SBL
MODEL: SM-G570M
REGION: LTN
PROVIDER: OPEN
PDA: G570MUBU2BRA3 [january 2018, rev3]
PIT
PIT written to file: "Backup/SM-G570M/PIT/SM-G570M_35495771.pit"
Finished at local time: [03.28.18 17:25:21]
WorkID: 35495771
can u pls guide me to take the frp for this phone.
Old 03-29-2018, 13:40   #14 (permalink)
paulo pessoa's Avatar
Member: 1474113
Sonork: 100.1604217
Thanks Meter: 474
DVIF
CAPA: 16
FWVER: 3
MODEL: SM-G570M
PRODUCT: Q313BB
UN: CQ300CF48C8B214
VENDOR: SAMSUNG
SBL
MODEL: SM-G570M
REGION: LTN
PROVIDER: OPEN
PIT
WorkID: 35495771
friend you can ignore the FRP using combination, then a flash with files 4.
can use according to binary.
http://forum.gsmhosting.com/vbb/f898...files-2355264/
Page generated in 0.21951 seconds with 8 queries
