01-05-2020, 13:47 | #1 (permalink) |
Freak Poster Join Date: Feb 2018 Location: UZB
Member: 2808071 Status: Offline Sonork: none Thanks Meter: 97 | Samsung J5 Pro SM-J530FM U7 Android 9 PIE Imei Repair Done Code: Chimera Mobile Phone Utility version: 23.32.0922 @ 2020-01-05 Printing phone history Get Info 2020-mm-05 6:29:40 Rmm Unlock 2020-mm-05 6:07:42 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530FM Sales Code: SKZ Country Code: Kazakhstan Timezone: Asia/Tashkent Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Aug 21 16:55:05 KST 2019 PDA Version: J530FMXXU7CSH8 [august 2019, rev8] Phone Version: J530FMXXU7CSH5 [august 2019, rev5] CSC Version: J530FMOXY7CSH5 [august 2019, rev5] Product Code: SKZ HIDSw Version: J530FMXXU7CSH8/J530FMOXY7CSH5/J530FMXXU7CSH5/J530FMXXU7CSH8 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8J70PDA2D Imei: 35643********** Unique Number: CAJ00E760EE9964 Connections: AT,MTP Battery Status: 3.87V (38%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-08-01 Data Encryption State: encrypted Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 356************ Repaired imei: 35************* Current imei2: 35************** Repaired imei2: 35************* Successfully finished. Finished at local time: [01.05.20 11:32:34] WorkID: 85057772 Code: Chimera Mobile Phone Utility version: 23.32.0922 @ 2020-01-05 Printing phone history Rmm Unlock 2020-mm-05 7:25:55 Patch Certificate 2020-mm-05 6:33:23 Repair IMEI 2020-mm-05 6:30:39 Get Info 2020-mm-05 6:29:40 Rmm Unlock 2020-mm-05 6:07:42 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530FM Sales Code: SKZ Country Code: Kazakhstan Timezone: Asia/Tashkent Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Wed Aug 21 16:55:05 KST 2019 PDA Version: J530FMXXU7CSH8 [august 2019, rev8] Phone Version: J530FMXXU7CSH5 [august 2019, rev5] CSC Version: J530FMOXY7CSH5 [august 2019, rev5] Product Code: SKZ HIDSw Version: J530FMXXU7CSH8/J530FMOXY7CSH5/J530FMXXU7CSH5/J530FMXXU7CSH8 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8J70PDA2D Imei: 355773********* Unique Number: CAJ00E760EE9964 Connections: AT,MTP Battery Status: 3.80V (28%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-08-01 Data Encryption State: unsupported Preparing... Checking root access. The phone is rooted by: 20.2:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [01.05.20 13:28:19] WorkID: 85061910 |
The Following 2 Users Say Thank You to Mardanov.T For This Useful Post: |
11-15-2020, 11:39 | #4 (permalink) |
Freak Poster Join Date: Nov 2017 Location: midrand
Member: 2783412 Status: Offline Sonork: 1680285 Thanks Meter: 226 | Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530F Sales Code: XSG Country Code: UAE Timezone: Africa/Johannesburg Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Jun 22 17:05:30 KST 2020 PDA Version: J530FXWS7CTF4 [june 2020, rev4] Phone Version: J530FXXS7CTF1 [june 2020, rev1] CSC Version: J530FOJV7CTF1 [june 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K33RZ09X Imei: 354310000000 Imei2: 3541000000 Battery Status: 4.13V (91%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [11.15.20 12:09:31] WorkID: 115373380 |
11-16-2020, 12:57 | #5 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Hello, Thank you for the report, we will investigate the problem. As it seams now, the binary version is the problem. We hope that we can update this issue within a short time. Quote:
The Following 3 Users Say Thank You to Chimera Tool For This Useful Post: |
11-24-2020, 16:56 | #6 (permalink) |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530F Sales Code: XSG Country Code: UAE Timezone: Asia/Tehran Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Jun 22 17:05:30 KST 2020 PDA Version: J530FXWS7CTF4 [june 2020, rev4] Phone Version: J530FXXS7CTF1 [june 2020, rev1] CSC Version: J530FOJV7CTF1 [june 2020, rev1] Product Code: XSG HIDSw Version: J530FXWS7CTF4/J530FOJV7CTF1/J530FXXS7CTF1/J530FXWS7CTF4 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: 430B61BCB0A791F1 Imei: 000000000000000 Connections: AT,MTP Battery Status: 3.95V (39%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [11.24.20 19:24:05] WorkID: 116435176 |
The Following User Says Thank You to BABAK NURI For This Useful Post: |
11-24-2020, 17:12 | #7 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Hello, Yes that is the same problem as previously was mentioned. The same binary version is installed. Unfortunately we cannot handle it at the moment. Quote:
11-25-2020, 15:51 | #10 (permalink) |
Freak Poster Join Date: Dec 2015 Location: iran
Member: 2499218 Status: Offline Thanks Meter: 44 | Chimera Mobile Phone Utility version: 26.65.1300 @ 2020-11-25 Printing phone history Repair IMEI 11/25/2020 2:47 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J530F Sales Code: THR Country Code: IRAN Timezone: Asia/Tehran Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Jun 22 17:05:30 KST 2020 PDA Version: J530FXWS7CTF4 [june 2020, rev4] Phone Version: J530FXXS7CTF1 [june 2020, rev1] CSC Version: J530FOJV7CTF1 [june 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K11WLLKH Imei: 354051092217764 Imei2: 354052092217762 Battery Status: 3.83V (50%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-06-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [11.25.20 18:19:14] WorkID: 116549925 |
