02-13-2019, 16:16
#1 (permalink)
Member: 2669781
Thanks Meter: 1,842 | HTC M9 HIMAUHL_{Bootloader Lock}_Successfully Removed.."1Click" Full logs of the operation/ Quote: Quote:
Chimera Mobile Phone Utility version: 20.22.1434 @ 2019-02-13
Printing phone history
Unlock bootloader
13/02/2019
15:07:29
Bootloader unlock started
Checking Bootloader state...
Phone detected
Using new method
Rebooting in Bootloader mode
Phone detected
Bootloader is locked
Rebooting in download mode
Phone detected
Successfully started in fastboot mode.
Gathering Bootloader information
All user data will be lost and the phone will be reset to factory default!
You will see the disclaimer on the screen now. Please read this carefully as this action may void your warranty.
Please select Yes to continue the procedure. Use the volume buttons to highlight your choice and the Power button to make your selection
(If you select Yes, your phone will be reset to its factory default settings and your Bootloader will be unlocked. If you select No, your phone will reboot and no modifications will be made.)
Successfully finished
Finished at local time: [02.13.19 16:11:03]
WorkID: 52465730
