03-02-2021, 13:03 | #1 (permalink) |
Crazy Poster Join Date: Oct 2019 Location: West Africa
Member: 2932917 Status: Offline Thanks Meter: 2 | Huawei ime repair error Testing connection... Checking IMEI(s)... Authenticating... This may take a while. Be patient! Do NOT disconnect the phone! The device sent an invalid challenge. Retry 2/5 The device sent an invalid challenge. Retry 3/5 The device sent an invalid challenge. Retry 4/5 The device sent an invalid challenge. Retry 5/5 The device sent an invalid challenge. Authentication with the device failed. Finished at local time: [03.02.21 07:54:21] WorkID: 126612426 |
03-02-2021, 15:26 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,742 | reply Hello, The IMEI REPAIR is a relatively old method, which one is not workable for the newer firmware/ security patch versions. We did replace that service with the IMEI RECOVERY and with the WRITE CERT. Best regards Sab Quote:
03-02-2021, 16:42 | #3 (permalink) |
Member: 2932917 Status: Offline Thanks Meter: 2 | Pls how do i connect the device to be able to fix the imei using the new method pls. Its the 3rd day now i have been bathling with this and chimera team has not given any detailed guide on how these operations should be performed. Thanks for your quick response. |
03-02-2021, 17:10 | #4 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,742 | reply We checked your work again. The device is an MHA-L29, so that means that we can perform the previously mentioned IMEI RECOVERY and the WRITE CERT. How should you start? You have to connect the device in ADB mode. So that means that you have to enable the usb debugging on the device. Just after that connect the phone with an original Huawei cable to the Tool. Then you will see the IMEI RECOVERY and the WRITE CERT. Which one should you use? It depends on the problem that you face of course. The IMEI RECOVERY can and will restore the device original IMEI number. With this function you cannot change the imei number to a totally different number. The WRITE CERT can change the imei number of the device. But to be able to use it, you have to have a CERT file. The Chimera Tool does provide the READ CERT service for these cases. With that method, you can read out the cert files from another device (same model with a good network), and you can use the WRITE CERT to load those files to the damaged phone. None of these services will require credits from you. Best regards Sab Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
03-03-2021, 05:45 | #6 (permalink) | |
No Life Poster Join Date: Sep 2007 Location: pakistan
Member: 583290 Status: Offline Thanks Meter: 107 | Quote:
useful information for all.its now like samsung cert base process for new huawei devices and service issue will also relate with blacklist or clean cert file. | |
03-04-2021, 11:41 | #10 (permalink) |
Member: 2932917 Status: Offline Thanks Meter: 2 | Chimera Mobile Phone Utility version: 27.71.0928 @ 2021-03-04 Printing phone history Usb Firmware Update 3/1/2021 9:06 AM Get Info 3/1/2021 9:03 AM Gathering information... Reading identifiers... SN: AHK7N16B02000195 Information Wifi MAC: 7c:11:cb:18:a0:17 Bluetooth MAC: 7c:11:cb:18:a3:1c SIM card 1 state: ABSENT SIM card 2 state: ABSENT Model name: MHA Manufacturer: HUAWEI Device code: HWMHA Product name: MHA ABI: arm64-v8a Multisim Config: dsds Language: zh Region: CN Android version: 9 Build id: HUAWEIMHA Build display id: MHA-LGRP2-OVS 9.1.0.252 Build description: generic_a15-user 9 PPR1.180610.011 eng.jslave.20190629.035607 test-keys Build date: Sat Jun 29 03:55:20 CST 2019 Build UTC: 1561751720 Build characteristics: default Build product: MHA Build fingerprint: HUAWEI/MHA/HWMHA:9/HUAWEIMHA/MHA-LGRP2-OVS 9.1.0.252:user/release-keys Build security patch: 2019-07-05 Build SDK version: 28 Boot build date (UTC): 1561751923 Boot verified boot state: green Boot build fingerprint: Huawei/generic_a15/generic_a15:9/PPR1.180610.011/jslave3201906290355:user/test-keys Boot serial: AHK7N16B02000195 FRP PST: /dev/block/bootdevice/by-name/frp GSM version: 21C30B323S006C000,21C30B323S006C000 Current phone type: 1,1 Network type: UMTS,Unknown RIL version: android infineon balong-ril 1.0 Data encryption state: encrypted SOC: hi3660 Board type: MHA Board platform: hi3660 UsbConfig: manufacture,adb Debuggable: 0 Finished at local time: [03.04.21 11:40:57] WorkID: 126881127 |
03-04-2021, 12:58 | #12 (permalink) | |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, please downgrade to lower version of Android or use board firmware Quote:
03-09-2021, 04:57 | #14 (permalink) |
Member: 2932917 Status: Offline Thanks Meter: 2 | I have downgraded the software and the imei repair issue is still not solved. I am so disappoinmted with chimeratool support. They cannot follow up complaints and make sure it is resilved, well there is no problem but i feel terribly bad with them. |
03-09-2021, 11:27 | #15 (permalink) |
Member: 1787203 Status: Online Thanks Meter: 23,742 | reply Dear User, Sorry far the late reply, actually Shensohau provided the solution for you. Yes you have to flash an older firmware version to the device. Most users using the following one: 8.0.0.373(C605) Please try to use this one. In the meantime we already replaced the IMEI REPAIR generally with two other services: Imei recovery and Write cert. For the new android versions you have to use those ones. Note: This two is not added to every device.Not yet at least. Best regards Sab |
