12-06-2016, 19:11 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Dear Users, Dwnload the drivers from the follow link: Android_CDC_Driver - Download - 4shared - Chimera Tool Install it and try again the process. |
12-07-2016, 11:51 | #4 (permalink) |
Freak Poster Join Date: Nov 2006 Location: Ireland
Member: 397374 Status: Offline Thanks Meter: 26 | Problem is not a connection with chimera or drivers. Problem is in Huawei phones, that some of them don't accept *#*# 2846579#*#* to enter engineer mode. just nothing happens when I dial the code. Any other way to enter this mode? thank you |
12-07-2016, 12:58 | #5 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
A) Enable "manufacture mode" on your phone. This is done by entering in dial pad code *#*#2846579#*#*, select "Project Menu", "Background settings", "USB ports settings", "Manufacture mode". Then connect it to PC and install drivers B) Install drivers for your phone by downloading and installing HiSuite software or by downloading this driver pack and applying drivers manually. After driver installation your phone in device manager must look like in the image below Please check if you have the image connection or upload to the forum as you can see the connection of your phone. Otherwise and if you do not upload more specific information, it is very difficult to help you. | |
The Following User Says Thank You to gcceleghg For This Useful Post: |
12-07-2016, 14:49 | #6 (permalink) |
Member: 397374 Status: Offline Thanks Meter: 26 | I don't know if you read question or you just answer automatically from some template. I don't have problems with drivers or anything. That is the problem : Enable "manufacture mode" on your phone. This is done by entering in dial pad code *#*#2846579#*#*, Dial pad code doesn't work. It has nothing to do with chimera. Just Huawei thing... Anybody faced this problem ? |
01-11-2017, 13:31 | #10 (permalink) | |
Please download the necessary driver and install it. After that, try again the process. https://www.4shared.com/web/directDo...37deb6936ad02b Solved Manufacture Port search. | |
01-12-2017, 15:54 | #13 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply You need not enter the mentioned code. 1. Connect your device to the computer 2. open the notification shade on the phone 3. here you can find the status of the connection, for example it is connected only for charge etc.. and you can switch it to pc suite in many case and it can solve the problem. Best regards Nicole |
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post: |
05-06-2017, 13:59 | #15 (permalink) |
Freak Poster Join Date: Jan 2014 Location: pakistan
Member: 2114397 Status: Offline Thanks Meter: 157 | Huawei Y6 Elite LYO-L02 Network unlocking not done with chimera tool Huawei Y6 Elite LYO-L02 Network unlocking not done with chimera tool *#*#2846579#*#* code work but not port enable option in hide menu Chimera Mobile Phone Utility version: 13.70.1500 @ 2017-05-06 Printing phone history Direct Unlock 5/6/2017 12:51:43 PM Direct Unlock 5/6/2017 12:49:08 PM Direct Unlock 5/6/2017 12:27:39 PM Development Support 5/6/2017 12:26:30 PM Direct Unlock 5/6/2017 12:25:38 PM [Removing network lock...] Searching for Manufacture port... Unknown error happend. Finished at local time: [05.06.17 17:55:13] WorkID: 20839974 Last edited by atiqmalik; 05-06-2017 at 14:05. |
