Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 12-06-2016, 18:43   #1 (permalink)
Member: 397374
Thanks Meter: 26
Huawei Manufacture port code not working
Hello,
It's my 3rd Huawei in a row that code for service menu doesn't work.
Any ideas?
Thank you
Old 12-06-2016, 19:11   #2 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Dear Users,
Dwnload the drivers from the follow link:
Android_CDC_Driver - Download - 4shared - Chimera Tool
Install it and try again the process.
Old 12-07-2016, 11:29   #3 (permalink)
Shensohau's Avatar
Member: 1377783
Sonork: 100.1611724
Thanks Meter: 3,335
Hi, wich model are you trying to connect with chimera???
Best Regards
Shensohau
Old 12-07-2016, 11:51   #4 (permalink)
Member: 397374
Thanks Meter: 26
Problem is not a connection with chimera or drivers. Problem is in Huawei phones, that some of them don't accept *#*# 2846579#*#* to enter engineer mode. just nothing happens when I dial the code. Any other way to enter this mode?
thank you
Old 12-07-2016, 12:58   #5 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Originally Posted by okrongly View Post
Hello,
Any ideas?
Thank you
Dear user!
A) Enable "manufacture mode" on your phone. This is done by entering in dial pad code *#*#2846579#*#*, select "Project Menu", "Background settings", "USB ports settings", "Manufacture mode". Then connect it to PC and install drivers
B) Install drivers for your phone by downloading and installing HiSuite software or by downloading this driver pack and applying drivers manually. After driver installation your phone in device manager must look like in the image below
Please check if you have the image connection or upload to the forum as you can see the connection of your phone.
Otherwise and if you do not upload more specific information, it is very difficult to help you.
The Following User Says Thank You to gcceleghg For This Useful Post:
Old 12-07-2016, 14:49   #6 (permalink)
Member: 397374
Thanks Meter: 26
I don't know if you read question or you just answer automatically from some template. I don't have problems with drivers or anything.
That is the problem :
Dial pad code doesn't work. It has nothing to do with chimera. Just Huawei thing...
Anybody faced this problem ?
Old 12-07-2016, 15:34   #7 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,706
reply
Dear Sir,
could you write me the exact model name of your device.
Thank you in advance!
best regards
Nicole
thank you
Old 12-07-2016, 18:38   #8 (permalink)
Member: 397374
Thanks Meter: 26
Originally Posted by Chimera Tool View Post
Dear Sir,
best regards
Nicole
Today I've had :
Y560-L01
Y625
The Following User Says Thank You to okrongly For This Useful Post:
Old 01-11-2017, 13:05   #9 (permalink)
Member: 397374
Thanks Meter: 26
Is there any other way to enable MAnufacture Port different than typing this code (it doesn't work on many models)
Thanks
Old 01-11-2017, 13:31   #10 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Thanks
Dear Sir,
Please download the necessary driver and install it. After that, try again the process.
https://www.4shared.com/web/directDo...37deb6936ad02b
Solved Manufacture Port search.
Old 01-11-2017, 17:29   #11 (permalink)
Member: 1787203
reply
if it is possible choose the pc suite as the connection type instead of the MTP.
It can solve that problem too.
Best regards
Nicole
Thanks
The Following 2 Users Say Thank You to Chimera Tool For This Useful Post:
Old 01-12-2017, 14:16   #12 (permalink)
Member: 397374
Thanks Meter: 26
But the problem is that *#*#2846579#*#* does NOTHING
Old 01-12-2017, 15:54   #13 (permalink)
Member: 1787203
reply
You need not enter the mentioned code.
1. Connect your device to the computer
2. open the notification shade on the phone
3. here you can find the status of the connection, for example it is connected only for charge etc.. and you can switch it to pc suite in many case and it can solve the problem.
Best regards
Nicole
The Following 4 Users Say Thank You to Chimera Tool For This Useful Post:
Old 01-12-2017, 17:12   #14 (permalink)
Member: 397374
Thanks Meter: 26
Will try this with another phone and will post results. Thank you
Old 05-06-2017, 13:59   #15 (permalink)
Member: 2114397
Thanks Meter: 157
Huawei Y6 Elite LYO-L02 Network unlocking not done with chimera tool
*#*#2846579#*#* code work but not port enable option in hide menu
Chimera Mobile Phone Utility version: 13.70.1500 @ 2017-05-06
Printing phone history
Direct Unlock
5/6/2017
12:51:43
PM
Direct Unlock
5/6/2017
12:49:08
PM
Direct Unlock
5/6/2017
12:27:39
PM
Development Support
5/6/2017
12:26:30
PM
Direct Unlock
5/6/2017
12:25:38
PM
[Removing network lock...]
Searching for Manufacture port...
Unknown error happend.
Finished at local time: [05.06.17 17:55:13]
WorkID: 20839974
Page generated in 0.32748 seconds with 8 queries
