07-10-2020, 10:21 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Hatfield Harare Zimbabwe Age: 42
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Huawei Mate 20 SNE-LX2 8.2.0.132(C185) fastboot only Code: Chimera Mobile Phone Utility version: 25.33.1824 @ 2020-07-10 Printing phone history Repair boot 7/10/2020 9:07:33 AM Load Factory Fastboot 7/10/2020 9:00:52 AM Repair boot 7/10/2020 9:00:31 AM Get Info 7/9/2020 12:09:06 PM Get Info 7/9/2020 7:23:39 AM Gathering information... Device Model: SNE-LX2 Current software version: SNE-LX2 8.2.0.132(C185) Hardware version: Ver2.3 Boot info: locked Image check: secure image verify fail Android version: 8.1.0 System version: SNE-LX2 8.2.0.132(C185CUSTC185D1) Battery state: 0 Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.6 Phone info: (bootloader) main version do not exist in oeminfo! VendorCountry: hw/meafnaf Finished at local time: [07.10.20 11:08:31] WorkID: 100329708 |
07-10-2020, 12:01 | #2 (permalink) |
No Life Poster Join Date: Nov 2017 Location: Russian
Member: 2778414 Status: Offline Thanks Meter: 342 | Hello Yes you needed run testpount load fastboot ( unlock ) and flash via fastboot update.app and other! |
The Following User Says Thank You to solgeo For This Useful Post: |
07-10-2020, 13:51 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Hi, when your device can not be started in eRecovery/USB Update mode we can recognize it in fastboot mode, but the device can not be repaired. First of all please use TP, then HUAWEI USB COM port will be available and you are able to choose the correct model number in a chimera software. Then 1. start Load Factory Fastboot, your device will be restart 2. now you can start the FRP remove process. 3. start repair recovery (after the successfully frp lock remove only), use only compatible sw version. Really important: sw package must be offline_update 4. After the successfully processes the device can be turned on and use without FRP lock Best regards Nicole Quote:
The Following User Says Thank You to Chimera Tool For This Useful Post: |
07-12-2020, 15:00 | #4 (permalink) | |
Member: 2377686 Status: Offline Sonork: 100.1668474 Thanks Meter: 315 | Now it cant repair recovery Quote:
