05-22-2021, 06:36 | #1 (permalink) |
Freak Poster Join Date: Apr 2017 Location: Tajikistan
Member: 2704006 Status: Offline Thanks Meter: 181 | SM-G985F U6-U7 Android 11 remove demo, repair imei, patch cert done Soon i send this solution in Chimera team. Thanks for Chimera team. Repair imei: Code: Chimera Mobile Phone Utility version: 28.49.1227 @ 2021-05-22 Printing phone history Get Info 22.05.2021 5:25 Demo Remove 20.05.2021 8:08 Repair IMEI 20.05.2021 8:02 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: WWD Sales Code: ZTO Country Code: Brazil Timezone: Asia/Dushanbe Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Feb 5 18:00:39 KST 2021 PDA Version: G985FXXU6DUB5 [february 2021, rev5] Phone Version: G985FXXU6AUA1 [january 2021, rev1] CSC Version: G985FOXB6DUB5 [february 2021, rev5] Product Code: ZTO HIDSw Version: G985FXXU6DUB5/G985FOXB6DUB5/G985FXXU6AUA1/G985FXXU6DUB5 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N12LMR2E Imei: 000000000000000 Connections: AT,MTP Battery Status: 3.73V (17%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-02-01 Em Did: 200A74F63E114011 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 000000000000000 Repaired imei: 353912116370155 Current imei2: 000000000000000 Repaired imei2: 353912118621118 Successfully finished. Finished at local time: [05.22.21 10:30:28] WorkID: 135149812Chimera Mobile Phone Utility version: 28.49.1227 @ 2021-05-22 Printing phone history Get Info 22.05.2021 5:25 Demo Remove 20.05.2021 8:08 Repair IMEI 20.05.2021 8:02 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: WWD Sales Code: ZTO Country Code: Brazil Timezone: Asia/Dushanbe Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Feb 5 18:00:39 KST 2021 PDA Version: G985FXXU6DUB5 [february 2021, rev5] Phone Version: G985FXXU6AUA1 [january 2021, rev1] CSC Version: G985FOXB6DUB5 [february 2021, rev5] Product Code: ZTO HIDSw Version: G985FXXU6DUB5/G985FOXB6DUB5/G985FXXU6AUA1/G985FXXU6DUB5 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N12LMR2E Imei: 000000000000000 Connections: AT,MTP Battery Status: 3.73V (17%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-02-01 Em Did: 200A74F63E114011 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 000000000000000 Repaired imei: 35391------- Current imei2: 000000000000000 Repaired imei2: 35391-------- Finished at local time: [05.22.21 10:30:28] WorkID: 135149812 Patch Cert: Code: Chimera Mobile Phone Utility version: 28.49.1227 @ 2021-05-22 Printing phone history Repair IMEI 22.05.2021 5:28 Get Info 22.05.2021 5:25 Demo Remove 20.05.2021 8:08 Repair IMEI 20.05.2021 8:02 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Carrier ID: WWD Sales Code: ZTO Country Code: Brazil Timezone: Asia/Dushanbe Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Fri Feb 5 18:00:39 KST 2021 PDA Version: G985FXXU6DUB5 [february 2021, rev5] Phone Version: G985FXXU6AUA1 [january 2021, rev1] CSC Version: G985FOXB6DUB5 [february 2021, rev5] Product Code: ZTO HIDSw Version: G985FXXU6DUB5/G985FOXB6DUB5/G985FXXU6AUA1/G985FXXU6DUB5 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N12LMR2E Imei: 3539------------ Connections: AT,MTP Battery Status: 3.79V (16%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-02-01 Em Did: 200A74F63E114011 Preparing... Checking root access. The phone is rooted by: b76c80e2:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.22.21 10:33:47] WorkID: 135149981 |
05-22-2021, 15:08 | #2 (permalink) |
Insane Poster Join Date: May 2020 Location: Germany
Member: 2955848 Status: Offline Thanks Meter: 18 | hi, thanks for your help chimera support android 11 for the folowing devices a515f g980f n975f a405fn g780f g988b if you can write your solution here so all of us can make longer list for android 11 |
05-25-2021, 12:45 | #3 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear sanno-2020, Thank you for the request we will forward your suggestion to the developers. We are already working on the Android 11 but we need time to have a proper update. Best regards Sab Chimera Team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
05-25-2021, 23:18 | #4 (permalink) | |
Member: 2955848 Status: Offline Thanks Meter: 18 | Quote:
i mean this list are already supported in android 11 according to Chimera team | |
