08-27-2021, 16:37 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | huawei nova 8 pro 5G BRQ-AN00 can i remove huawei id? Chimera Mobile Phone Utility version: 29.39.1120 @ 2021-08-27 Printing phone history Removing Huawei account Uploading data Failed to read, try to hard-reset the phone Finished at local time: [08.27.21 12:34:43] WorkID: 147916952 |
The Following User Says Thank You to alexis_01 For This Useful Post: |
08-28-2021, 05:59 | #2 (permalink) | |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | Quote:
Chimera Mobile Phone Utility version: 29.39.1120 @ 2021-08-28 Printing phone history Get Info 28/08/2021 4:53 Removing Huawei account Rebooting phone to factory mode Changing to factory mode Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished Uploading data Failed to read, try to hard-reset the phone Finished at local time: [08.28.21 01:54:16] WorkID: 147974785 | |
08-30-2021, 09:59 | #4 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, Please try to flash an EU/Global firmware to the device and then run the process once again. Just to make sure: reinstall the Huawei drivers - in the chimera tool settings menu. Best regards Sab Chimera team Quote:
12-08-2021, 21:33 | #5 (permalink) |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | Hello, to this day I am still trying to remove the huawei account id from this BRQ-AN00 model. I have the modified cable that works perfect because I have tested it with other huawei and still it continues with the same failure. Chimera Mobile Phone Utility version: 30.49.1425 @ 2021-12-08 Printing phone history Huawei Id & Frp Remove 08/12/2021 20:27 Huawei Id & Frp Remove 08/12/2021 0:14 Huawei Id & Frp Remove 07/12/2021 23:20 Huawei Id & Frp Remove 07/12/2021 23:18 Huawei Id & Frp Remove 07/12/2021 23:16 Removing Huawei account Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [12.08.21 17:28:37] WorkID: 161304804 |
12-09-2021, 11:35 | #6 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, When the tool tells you to reset the phone please do it. Also if the tool asks you for the reconnection, make sure that you disconnect the cable from the PC end, and from the phones end. Best regards Sab Chimera team Quote:
12-09-2021, 13:13 | #7 (permalink) | |
I have done exactly what the tool indicates and the problem persists, I have reset the phone several times and the problem persists. | |
06-14-2022, 15:30 | #13 (permalink) | |
No Life Poster Join Date: Jul 2011 Location: Nairobi, Kenya
Member: 1610674 Status: Offline Sonork: 210921 Thanks Meter: 217 | Quote:
Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [06.14.22 17:19:27] WorkID: 184071882 | |
06-14-2022, 15:36 | #14 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Dear User, Please run a HARD RESET on the device. Which means press and hold the POWER button while the device is connected to the pc / tool. Hold the button for about 15-20 sec. Then click on the EXIT FACTORY MODE. Also make sure that you reinstall the Huawei drivers (In the chimera tool - settings menu) before you do that! Best regards Sab Chimera team |
03-29-2024, 01:24 | #15 (permalink) |
No Life Poster Join Date: Jun 2015 Location: the planet earth
Member: 2406539 Status: Offline Thanks Meter: 101 | same error.. huawei nova 8 pro 5g aka (BRQ-AN00) id not removed.. always stuck at 74% and showing error.. Chimera Mobile Phone Utility version: 38.92.2051 Removing Huawei account Uploading data... Failed to read, try to hard-reset the phone Finished at local time. WorkID: 267768531 Last edited by TMAC1122; 03-29-2024 at 01:31. |
