Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 05-12-2021, 19:14   #1 (permalink)
Member: 2266273
Sonork: Iqbal008
Thanks Meter: 16
Samsung A217f after pach ng problem
Samsung A217f imei repair and patch cert done but still ng solution need I try different firmware
Old 05-13-2021, 09:44   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,706
reply
Dear User,
Please do a Factory Reset on the phone. After it do the reflashing. Make sure that you root the device again, and just after that do the IMEI REPAIR and the PATCH CERT method.
Best regards
Sab
Chimera Team
Old 05-17-2021, 16:39   #3 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 234
Exclamation Samsung A217m after pach ng
Chimera Mobile Phone Utility version: 28.46.0853 @ 2021-05-17
Printing phone history
Repair IMEI
5/17/2021
3:04
PM
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-A217M
Carrier ID: PET
Sales Code: PET
Country Code: PERU
Timezone: America/Lima
Android Version: 10 [QP1A.190711.020] [SDK 29]
Build Date: Thu Nov 19 03:21:29 KST 2020
PDA Version: A217MUBS3ATK2 [november 2020, rev2]
Phone Version: A217MUBS3ATK1 [november 2020, rev1]
CSC Version: A217MOWA3ATJ1 [october 2020, rev1]
Board Platform: UNIVERSAL3830
Modem Platform: SHANNON318
Serial Number: R58NB34RLJA
Imei: 356001xxxxxxxx
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2020-11-01
Em Did: 200395AE10DAEE11
Preparing...
Checking root access.
The phone is rooted by: fe4981da:MAGISKSU
Previously installed patchcert detected.
Previously installed patchcert successfully removed.
Reading data...
The operation is in progress. Be patient! Do NOT disconnect the phone!
Patching certificate...
About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
After installing new firmware, the patchcert process must be repeated.
Successfully finished.
Finished at local time: [05.17.21 10:35:08]
WorkID: 134514248
Old 05-17-2021, 16:42   #4 (permalink)
Member: 1787203
reply
Dear m&s,
I can suggest you the same as before. Please reflash the phone and then repeat the rooting. After that, do the IMEI REPAIR and the PATCH CERT once more.
Repair IMEI
5/17/2021
3:04
PM
Model: SM-A217M
Carrier ID: PET
Sales Code: PET
Country Code: PERU
Network Type: GSM
SIM Status: LOADED
Multisim Config: SS
Knox Version: v30
Warranty Bit: 1
Preparing...
Reading data...
WorkID: 134514248
Old 05-17-2021, 17:14   #5 (permalink)
m&s
m&s's Avatar
Member: 1168673
Sonork: 100.1638333
Thanks Meter: 234
Exclamation
Originally Posted by Chimera Tool View Post
Dear m&s,
Raise the signal for a few seconds and then only emergency will occur
Old 05-18-2021, 09:39   #6 (permalink)
Member: 1787203
reply
You have to repeat the process. Reflash the phone and then root it again , and then do the Patching. We have to force the service to the device.
Old 06-29-2021, 10:07   #7 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
Chimera Mobile Phone Utility version: 28.89.0801 @ 2021-06-29
Repair IMEI
29/06/2021
8:58
a.
m.
Repair IMEI
29/06/2021
8:55
a.
m.
Patch Certificate
29/06/2021
8:43
a.
m.
Repair IMEI
29/06/2021
8:41
a.
m.
Repair IMEI
29/06/2021
8:38
a.
m.
Repair started
Model: SM-A217M
Carrier ID: COB
Sales Code: CHL
Country Code: Chile
Timezone: America/Bogota
Build Date: Thu Jan 21 06:40:06 KST 2021
PDA Version: A217MUBS5AUA1 [january 2021, rev1]
Phone Version: A217MUBS5AUA1 [january 2021, rev1]
CSC Version: A217MOWA5AUA1 [january 2021, rev1]
Serial Number: RF8NB05ZCEV
Imei: 000000000000000
Network Type: GSM
SIM Status: UNKNOWN,UNKNOWN
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2021-01-01
Em Did: 2000D70E7788C111
Repair imei...
Repair imei failed.
Finished at local time: [06.29.21 04:01:57]
WorkID: 140126291
any solution?
Old 06-29-2021, 10:46   #8 (permalink)
Member: 1787203
reply
Dear jmr,
Please reflash the device. Use another firmware file and then boot up the phone from recovery. Then do the service for it.
Best regards
Sab
Chimera Team
Repair IMEI
29/06/2021
8:58
a.
m.
Repair IMEI
29/06/2021
8:55
a.
m.
Patch Certificate
29/06/2021
8:43
a.
m.
Repair IMEI
29/06/2021
8:41
a.
m.
Repair IMEI
29/06/2021
8:38
a.
m.
Repair started
Model: SM-A217M
Carrier ID: COB
Sales Code: CHL
Country Code: Chile
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Repair imei...
Repair imei failed.
WorkID: 140126291
any solution?
Old 07-30-2021, 09:14   #9 (permalink)
Member: 2985758
Thanks Meter: 29
A217f u3 i try with different firmwares root repair every thing done but still ng any one have salution
Old 07-30-2021, 09:46   #10 (permalink)
Member: 1787203
reply
Dear User,
Please try to do the process while the phone is in Airplane mode. Then do the Patch Cert again without the Airplane mode.
Best regards
Sab
Chimera Team
Page generated in 0.23325 seconds with 8 queries
