08-30-2021, 18:39 | #1 (permalink) |
Freak Poster Join Date: Aug 2007
Member: 565487 Status: Offline Sonork: 100.1590618 Thanks Meter: 35 | huawei p40 pro huaweid remove failed??? Printing phone history Huawei Id & Frp Remove 30.08.2021 17:20 Huawei Id & Frp Remove 30.08.2021 17:17 Huawei Id & Frp Remove 30.08.2021 17:07 Huawei Id & Frp Remove 30.08.2021 17:03 Enter Factory Mode 30.08.2021 17:01 Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished We counld't identify the device, please select manually, if present! Uploading data Uploading data Failed to read, try to hard-reset the phone Finished at local time: [08.30.21 19:34:52] WorkID: 148260973 |
08-30-2021, 23:11 | #5 (permalink) |
Freak Poster Join Date: Jan 2008 Location: HH +4940
Member: 686560 Status: Offline Thanks Meter: 68 | |
