PHONE STILL LOCKED Please make improvement on this device Code: Loading factory fastboot Code: Network Factory Reset 25-Sep-20 9:28 PM Code: Exit Factory Mode Code: Exit Factory Mode |
forgot samsung with a305g bit 6 a205g bit 6 j600g bit 7 many models for unlock a102u a205u |
Hello Team, Please UPDATE SAMSUNG PATCH CERT NEW VERSION |
reply Hi, Yes we try to do so. Hopefully it can be fixed within a short time. Quote:
Hello team, after the two last update now i cant services any huawei, it always failed, and before the update i can do same phone same firmware build, please fix the problem |
reply Hello, Please let us know a WORK ID from the problematic job, so we can check the issue. Thank you! Sab Quote:
Hi friend Ceck in you website SNE-LX1, is reported how Mate 20, but this model is Mate 20 lite, to avoid mistake for Newbie, edit this model ;) |
Huawei update Think its time to lower the price of write cert since sigma box is gree or add apack we know we cant pay for since we are disadvantaged compared to sigma users |
Hi. Please check Workid #128814485 and a lot of failed works with the same device. Thank you. |
reply Hello, We checked the Work ID that you mentioned. Can you please do the following methods: 1. Do a factory reset 2. Do a REPAIR RECOVERY 3. Then use the USB FIRMWARE UPDATE for the flashing. After these steps the device should be workable for you. Best regards Sab Chimera Team Quote:
Hi chimera team recently chimera enable dual sim activation funtion on recent huawei but i have issu with that funtion on mate 20 pro and p30 lite. i cant cant make calls and ussd code not worked on second sim slot please fix that. thank you |
reply Dear User, Can you please post a WORK ID from one of those dual sim convert jobs, so we can check the problem. Best regards Sab Chimera Team Quote:
for mate 20 pro= #128876823 for p30 lite= #128838993 |
i have need help 4 p20 pro... i didn't find a firmware... i have a phone Brand H3g Ita i try to remove a frp now is briked You can help me ? I have nee dflash it and remove the frp... Gathering information... Device Model: CLT-L09 Current software version: CLT-L09 9.0.0.231(C781E10R1P9) FB ID: LCL7N19109002644 Hardware version: Ver2.3 Boot info: unlocked Image check: secure image verify fail Android version: 9 System version: CLT-L09 9.0.0.170(C781E7R1P9) Battery state: 0 Key version: huawei_key_v1 Root info: RISK Rescue version: rescue0.6 Phone info: (bootloader) main version do not exist in oeminfo! VendorCountry: h3g/it Partition type: 0.5 Finished at local time: [03.30.21 00:46:38] WorkID: 129503630 |
