07-06-2020, 08:34 | #1 (permalink) |
Freak Poster Join Date: Jan 2014 Location: Turkey
Member: 2116376 Status: Offline Sonork: 100.1658454 Thanks Meter: 110 | i need help G950F Unsupported modem version. Code: Printing phone history Repair IMEI 7/6/2020 6:59:05 AM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: BTC Country Code: Libya Timezone: Europe/Istanbul Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri May 15 11:51:16 KST 2020 PDA Version: G950FXXS9DTEA [may 2020, revA] Phone Version: G950FXXS9DTE1 [may 2020, rev1] CSC Version: G950FOXM9DTE1 [may 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: RF8J50HSS3R Imei: 355090086030741 Battery Status: 3.84V (40%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Repair imei... Checking modem version. Reading modem. Be patient! Do NOT disconnect the phone! This modem is not appropriate (G950FXXS9DTE1). Please downgrade if possible! Unsupported modem version. Finished at local time: [07.06.20 10:02:09] WorkID: 99887742 |
07-06-2020, 13:15 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Online Thanks Meter: 23,753 | reply Hi, please install firmware with older modem version on your device and try again. Best regards Nicole Quote:
07-08-2020, 22:09 | #3 (permalink) |
Crazy Poster Join Date: May 2006
Member: 275869 Status: Offline Thanks Meter: 9 | Hi! I have the similar problem! I got stuck with this firmware because of Chimera when I flashed the device!! Now I have bootloader S9. As you know it is impossible to downgrade!! All the S9 bootloaders comes with unsupported modem! Is there any solution? or any date for new update that m8 fix the problem? |
07-08-2020, 22:12 | #4 (permalink) |
Member: 275869 Status: Offline Thanks Meter: 9 | Chimera Mobile Phone Utility version: 25.26.1633 @ 2020-07-08 Printing phone history Patch Certificate 2020-07-08 21:01:17 Read Cert 2020-07-08 19:24:36 Patch Certificate 2020-07-08 19:23:44 SW Change 2020-07-08 18:20:37 Patch Certificate 2020-07-08 18:16:49 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: NEE Country Code: Nordic Timezone: Europe/Stockholm Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri May 15 11:51:16 KST 2020 PDA Version: G950FXXS9DTEA [may 2020, revA] Phone Version: G950FXXS9DTE1 [may 2020, rev1] CSC Version: G950FOXM9DTE1 [may 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: Imei: Battery Status: 4.24V (99%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: 20.3:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [07.08.20 23:10:46] WorkID: 100195138 |
07-08-2020, 22:13 | #5 (permalink) |
Member: 275869 Status: Offline Thanks Meter: 9 | Chimera Mobile Phone Utility version: 25.26.1633 @ 2020-07-08 Printing phone history Patch Certificate 2020-07-08 21:10:35 Patch Certificate 2020-07-08 21:01:17 Read Cert 2020-07-08 19:24:36 Patch Certificate 2020-07-08 19:23:44 SW Change 2020-07-08 18:20:37 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G950F Sales Code: NEE Country Code: Nordic Timezone: Europe/Stockholm Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri May 15 11:51:16 KST 2020 PDA Version: G950FXXS9DTEA [may 2020, revA] Phone Version: G950FXXS9DTE1 [may 2020, rev1] CSC Version: G950FOXM9DTE1 [may 2020, rev1] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: Imei: Battery Status: 4.22V (99%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking current patchcert. Checking modem. Unsupported modem: G950FXXS9DTE1 Finished at local time: [07.08.20 23:13:02] WorkID: 100195320 |
07-09-2020, 14:22 | #6 (permalink) | |
Member: 1787203 Status: Online Thanks Meter: 23,753 | reply Hi, if it is possible please try with the follow version: PDA Version: G950FXXS8DTC6 [march 2020, rev6] Phone Version: G950FXXS8DTC1 [march 2020, rev1] CSC Version: G950FUWC8DTC1 [march 2020, rev1] The phone is rooted by: 20.4:MAGISKSU Best regards Nicole Quote:
07-10-2020, 08:29 | #7 (permalink) |
Member: 275869 Status: Offline Thanks Meter: 9 | Thanx 4 ur reply! This firmware u suggested has a bootloader wigh lower version, S8. As you know it is impossible to downgrade bootloader. Please come with more details if there is something I missed about this |
07-11-2020, 03:11 | #8 (permalink) |
Crazy Poster Join Date: May 2018
Member: 2839691 Status: Offline Thanks Meter: 15 | You can try flashing only the modem from combination firmware of the corresponding bit revision, for best success. |
The Following User Says Thank You to 1M31 For This Useful Post: |
07-11-2020, 12:31 | #10 (permalink) | |
Junior Member Join Date: Jun 2020 Location: BRAZIL Age: 41
Member: 2961010 Status: Offline Thanks Meter: 0 | Quote:
could you please teach me, how to change the file only from the modem, in the combination rom ??? I looked on the internet, but I couldn't find an explanation ... could you tell me in detail. I will try with the G980f. S20. | |
07-13-2020, 00:44 | #11 (permalink) | |
Member: 275869 Status: Offline Thanks Meter: 9 | Quote:
Thanx for ur reply There is no combination file for s9 bootloader version of this firmware. If I flash only the modem img from the combination file then the os will not recognise the modem at all!! Is there any other work around?? | |
