10-12-2014, 19:06 | #1 (permalink) |
No Life Poster Join Date: Jun 2007
Member: 534777 Status: Offline Thanks Meter: 214 | I9515 4.4.2 after unlock, emergency calls only Printing phone history Info 2014-10-09 04:39:00 FINISHED Info 2014-10-09 04:38:40 FINISHED [Unlock phone started.] Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: GT-I9515 Android Version: 4.4.2 Sales Code: XEF PDA Version: I9515XXU1ANC1 Phone Version: I9515XXU1ANC1 CSC Version: I9515OXX1ANC1 Board Platform: MSM8960 Serial Number: RF8F31SKKYL Imei: 3521680 Unlocking... 1. Disconnect micro USB cable. 2. On dial window enter *#0808# and set DM+MODEM+ADB. 3. Select OK on phone display. 4. Connect micro UART cable. 5. Click OK button. Testing availability. Be patient! Do NOT disconnect the phone! Preparing MSL. Be patient! Do NOT disconnect the phone! Null MSL detected. Was EFS cleared? Processing. Restart phone by using the phone's menu if it does not restart automatically! If needed use unlock code "00000000". The procedure was free. Finished successfully. Finished at local time: [10.12.14 17:47:46] WorkID: 2522571 |
10-14-2014, 02:04 | #4 (permalink) |
Member: 534777 Status: Offline Thanks Meter: 214 | what's the solution??? how do i fix this issue??? you should consider incorporating into your software an option to read the security data of the phone or even add it to the unlock process where it does it automatically so as to avoid these costly errors. |
10-14-2014, 04:10 | #6 (permalink) |
Member: 534777 Status: Offline Thanks Meter: 214 | @BFMarket. just thought i should add the PRINT HISTORY for your perusal: Chimera Mobile Phone Utility version: 4.34.1620 @ 2014-10-14 Printing phone history Info 2014-10-14 02:25:15 FINISHED Info 2014-10-14 02:24:26 FINISHED Info 2014-10-12 21:00:01 FINISHED Factory Unlock 2014-10-12 17:45:57 CANCELED Info 2014-10-09 04:39:00 FINISHED states FACTORY UNLOCK........CANCELED. so how come the success log generated by the software???? please assist. thanx. |
10-14-2014, 10:04 | #8 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | As you can see from the log file you was posted your EFS seems to by empty. "Null MSL detected. Was EFS cleared?" In this case your phone was damaged I'm very sure before and not ChimeraTool was the reason. |
10-16-2014, 03:25 | #9 (permalink) | |
Member: 534777 Status: Offline Thanks Meter: 214 | Quote:
besides how cld i have determined prior to unlocking that efs was intact or not hence i suggest you incorporate into your software an auto efs and/or security data back up before the unlock process is carried out. i wasn't out to blame your tool rather i'm seeking help so i'd appreciate any assistance from your end as to how to fix this problem. | |
10-16-2014, 10:50 | #10 (permalink) |
Moderator Join Date: Oct 2009 Location: Poland Age: 42
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | I think bug is in chimera software becosue I9515 is signed like G900 S5 and other new and software never should give you option to unlock(without credits) this phone in normal way, only possible option should be factory unlock. And if this is true that chimera never do backup nvzone before unlock will be good to add this option this is very usefull when any problem after unlock we see. Last edited by wgmmmx1; 10-16-2014 at 10:58. |
10-16-2014, 11:19 | #11 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,746 | Quote:
Yes of course I say thanks for your positive attitude. In your case the headset was 100% sure damaged before you was put it to the ChimeraTool, because as you can see at the first time you got warning message about EFS was cleared. This message occur in case when we can not read out some important parameters from the phone. We do not have solution for such damaged phones at the moment sorry. | |
10-16-2014, 11:22 | #12 (permalink) | |
It is not a bug, because we are using only factorial commands to set the codes to 00000000. In this case there is no way to make EFS backup, because there is no built in command in the OS for such function. However if you want or it is a demand, then we can implement it, but then phone should be root before... | |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
10-16-2014, 11:37 | #13 (permalink) | |
Member: 1139057 Status: Offline Sonork: 100.109924 Thanks Meter: 4,428 | Quote:
No need I not see exacly that he use factory unlock that never damage phone with this process backup is no needed. | |
10-16-2014, 11:39 | #14 (permalink) | |
For now only 1 tool can fix your problem and this is samsung tropical unlocker but need pay again for this no free action. Maybe soon chimera add this imei repair and network too will be great | |
10-16-2014, 12:03 | #15 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,746 | We could add it with using a GSPN account, but if we would release such "update" then account will be blocked in every day, better we will not fight with Korean guys |
