ine-lx1 dead after try change oem i have nova 3i work fine need only change oeminfo i connect testpoint .phone back already open chimera failed in change in phone dead try to write board firware not done battary oki try normal and heromny cable failed in fastboot load Chimera Mobile Phone Utility version: 31.43.0850 @ 2022-03-10 Printing phone history Load Factory Fastboot 10/25/2020 7:16 PM Modify Oeminfo Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. Operation failed Finished at local time: [03.10.22 19:11:57] WorkID: 172398575 Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone Uploading Fastboot... Selected version: kirin710_chimera_1 Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone Finished at local time: [03.10.22 19:14:25] WorkID: 172398779 |
reply Dear Xpress_banha, In what state is on the phone? Can you boot it up into Fastboot mode? Or it is in Factory mode (COM PORT:1 in device manager)? Best regards Sab Chimera team Quote:
no fastboot alwasys usb com 1 Chimera Mobile Phone Utility version: 31.43.0850 @ 2022-03-10 Printing phone history Load Factory Fastboot 3/10/2022 6:13 PM Load Factory Fastboot 12/26/2020 4:18 PM Load Factory Fastboot 10/14/2020 6:20 PM Load Factory Fastboot 9/26/2020 3:08 PM Loading factory fastboot Firmware extraction Extracting firmware Uploading Fastboot... Uploading data... Uploading data... Uploading data... Failed to read, try to hard-reset the phone The procedure has been canceled. Finished at local time: [03.10.22 20:32:49] WorkID: 172408524 |
