07-23-2021, 04:33 | #1 (permalink) |
Freak Poster Join Date: Apr 2015 Location: Somewhere I Belong Age: 35
Member: 2377851 Status: Offline Thanks Meter: 35 | J260M IMEI REPAIR BIT 13. How To? Today i hace tried to perform imei repair and Patch on J260M BIT13, All operations performed OK, But I always Get IMEI STATUS OK but Always EMERGENCY CALLS. IMEI Number is not BLACKLISTED. I Tried with Firmware from October and December 2020 Security Patch, But Always the same problem. I want to know , Which Firmware is the Required to perform IMEI REPAIR AND PATCH successfully Working. J260MUBSDATJ1 OCTOBER Security Patch Did not work J260MUBSDATL1 DECEMBER Security Patch Did not work. 🆘 Help. |
07-23-2021, 09:32 | #2 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, after repair just need wait until 60-180 seconds until device registered on network, as a Clue I reccomend use magisk for root... please before patch be sure ROOT acess is complete.... |
07-23-2021, 10:18 | #3 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Dear User, Please do a factory reset on the device. Then reflash the following firmware: J260MUBSDATJ1 [october 2020, rev1] After it root it, and then use the IMEI REPAIR and the PATCH CERT while the phone is in Airplane mode. Then run the Patch cert service while the Airplane mode is disabled. Best regards Sab Chimera Team Quote:
07-23-2021, 13:18 | #4 (permalink) | |
Member: 2377851 Status: Offline Thanks Meter: 35 | Quote:
I'll give it a try | |
07-23-2021, 13:21 | #5 (permalink) | |
I Flashed that firmware version yesterday but the problem still. Do you recommend to root with EFTSU or MAGISK? Ill try again... | |
07-23-2021, 21:03 | #8 (permalink) | |
The device still EMERGENCY CALL ONLY and Imei STATUS OK Dont know what else to do | |
