02-22-2019, 10:14 | #1 (permalink) |
Freak Poster Join Date: Feb 2018 Location: Zimbabwe
Member: 2807070 Status: Offline Sonork: 550000 Thanks Meter: 37 | J7 neo J701f Imei patch done but and sim card2 is not working only emergency |
02-22-2019, 12:50 | #3 (permalink) | |
Member: 2807070 Status: Offline Sonork: 550000 Thanks Meter: 37 | Quote:
Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J701F Sales Code: XFA Country Code: Timezone: Android Version: 8.1.0 [M1AJQ] [SDK 27] Build Date: Wed Sep 19 11:27:14 KST 2018 PDA Version: J701FXVU6BRI9 [september 2018, rev9] Phone Version: J701FXXU6ARH1 [august 2018, rev1] CSC Version: J701FOJV6BRI9 [september 2018, rev9] Product Code: XFA HIDSw Version: J701FXVU6BRI9/J701FOJV6BRI9/J701FXXU6ARH1/J701FXVU6BRI9 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8JA1C1X6M Imei: Unique Number: CAJ006400FE5694 Connections: AT,MTP Battery Status: 4.18V (82%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-09-01 Data Encryption State: encrypted Preparing... Checking current patchcert. Checking modem. Checking root. Checking boot image. Be patient! Do NOT disconnect the phone! Writing boot image. Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data. Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server. Be patient! Do NOT disconnect the phone! Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.22.19 10:23:38] WorkID: 53196076 hope you will solve this problem soon | |
The Following 2 Users Say Thank You to hasheemkapla559 For This Useful Post: |
03-07-2019, 09:39 | #4 (permalink) | |
No Life Poster Join Date: May 2008 Location: bhakkar Age: 38
Member: 770229 Status: Offline Sonork: 29050 Thanks Meter: 101 | Quote:
03-07-2019, 13:39 | #6 (permalink) |
No Life Poster Join Date: Feb 2015 Location: IRAN-TABRIIZ
Member: 2339474 Status: Offline Sonork: 100.1662352 Thanks Meter: 332 | for dual sim phones when sim2 is emergency mode but sim 1 is ok just get phone in offline mode and get back to normal mode sim2 network olso ok. |
03-08-2019, 10:52 | #9 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Hi, we have lot of successfully process, when you faced with some issue it is not mean we added "fake update".. It is worth to try again with other firmware and t start again from the first step the process. In a most case the sequence of the processes the reason of the problem. More info about them here: forum.gsmhosting.com/vbb/f898/samsung-imei-repair-patch-cert-check-tutorial-get-your-questions-answered-2564741/ Best regards Nicole |
