J701f 8.0.1 U6 after patch no network i repaired j701F 8.0.1 u6 BT NO NETWORK imei satus NG can you help |
use combination modem file and try patch again working 100% |
i have some problem tryed many times different firmware and modem i think chimera not support this version firmware |
reply Hi, can I ask the work id of the patch cert process please? Thank you in advance! Best regards Nicole Quote:
there must be a problem with your server or software because this morning i have tested with 3 pcs diffrent j701f with my own firmware which i have tested and patched succesfuly two days ago..but now every time with all method is ng....tested firmware,tested root,tested modem but problem is your software because i have repaired binnary 6 100 times before |
thank you |
Make sure you wait until device exits airplane mode automatically. Do not take it out yourself. It serves as an indicator for when the patch cert process has been completed. It runs each time device reboots. If you check imei status before it exits airplane mode automatically, patch vert process not completed yet, and it will show NG. If wait until after it exits automatically, it should be OK if succeeded. Only must have patience during airplane mode. If you notice device stuck in airplane mode more than 3 minutes, maybe process has failed, reattempt patch cert operation, and post workid so someone in forum can attempt to help. Without workid, it is difficult to help. |
