GSMSERVER GSM Shop
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 03-26-2019, 08:48   #1 (permalink)
Member: 1825426
Sonork: 100.1626329
Thanks Meter: 8
J701f 8.0.1 U6 after patch no network
i repaired j701F 8.0.1 u6 BT NO NETWORK imei satus NG can you help
Old 03-26-2019, 09:22   #2 (permalink)
Member: 770229
Sonork: 29050
Thanks Meter: 97
Binry u6 not working network
Old 03-26-2019, 09:47   #3 (permalink)
Member: 2339474
Sonork: 100.1662352
Thanks Meter: 328
use combination modem file and try patch again
working 100%
Old 03-26-2019, 11:01   #4 (permalink)
Member: 1825426
Sonork: 100.1626329
Thanks Meter: 8
working 100%
Tried this and still imei NG
Old 03-26-2019, 12:04   #5 (permalink)
Member: 1485377
Sonork: 100.1623194
Thanks Meter: 50
i have some problem tryed many times different firmware and modem i think chimera not support this version firmware
Old 03-26-2019, 12:37   #6 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 16,602
reply
Hi,
can I ask the work id of the patch cert process please?
Thank you in advance!
Best regards
Nicole
Old 03-26-2019, 13:28   #7 (permalink)
loniryan's Avatar
Member: 2279944
Sonork: not avaliable
Thanks Meter: 130
there must be a problem with your server or software because this morning i have tested with 3 pcs diffrent j701f with my own firmware which i have tested and patched succesfuly two days ago..but now every time with all method is ng....tested firmware,tested root,tested modem but problem is your software because i have repaired binnary 6 100 times before
Old 03-26-2019, 14:41   #8 (permalink)
Member: 1825426
Sonork: 100.1626329
Thanks Meter: 8
Originally Posted by Chimera Tool View Post
Hi,
Best regards
Nicole
Hi Sir Work ID is 55597098
thank you
Old 03-26-2019, 14:44   #9 (permalink)
chavonbravo's Avatar
Member: 952912
Thanks Meter: 140
Make sure you wait until device exits airplane mode automatically. Do not take it out yourself. It serves as an indicator for when the patch cert process has been completed. It runs each time device reboots.
If you check imei status before it exits airplane mode automatically, patch vert process not completed yet, and it will show NG. If wait until after it exits automatically, it should be OK if succeeded. Only must have patience during airplane mode.
If you notice device stuck in airplane mode more than 3 minutes, maybe process has failed, reattempt patch cert operation, and post workid so someone in forum can attempt to help. Without workid, it is difficult to help.
The Following 4 Users Say Thank You to chavonbravo For This Useful Post:
Page generated in 0.32277 seconds with 7 queries
