08-09-2021, 16:56 | #1 (permalink) |
Freak Poster Join Date: May 2016
Member: 2573102 Status: Offline Thanks Meter: 21 | j727p imei cert fail! After flash! Chimera Mobile Phone Utility version: 29.27.1031 @ 2021-08-09 Printing phone history Restore / Store backup 2021-08-09 3:13 PM Network Factory Reset 2021-08-09 3:13 PM Root/Unroot 2021-08-09 11:49 AM Read SPC/MSL 2021-08-09 11:49 AM Network repair 2021-08-09 11:48 AM Get info started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J727P Carrier ID: BST Sales Code: XAS Country Code: USA Timezone: Asia/Karachi Android Version: 8.1.0 [M1AJQ] [SDK 27] Build Date: Tue Jan 29 14:16:47 KST 2019 PDA Version: J727PVPS5BSA3 [january 2019, rev3] Phone Version: J727PVPS5BSA3 [january 2019, rev3] CSC Version: J727PSPT5BSA3 [january 2019, rev3] Board Platform: MSM8953 Modem Platform: MSM8953 Serial Number: 00000000000 Imei: 353559086634142 Battery Status: 3.87V (55%) Network Type: CDMA SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2019-02-01 Successfully finished. Finished at local time: [08.09.21 20:57:00] WorkID: 145598501 phone was in working condition in u3 binary and has it's original IMEI! but after updating to 8.1.0 u5 now ! Imei certi fail! one thing i notice is the phone doesn't have SN and MEID! is there an way to solve the problem? Thanx! if anyone can share this file can be helpful too! https://support.halabtech.com/index....file&id=160367 |
08-09-2021, 18:28 | #2 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Hi there! First you should be able to recover the original Imei of your phone by flashing with Chimera Tool and keeping the same binary. Take the test and upload the result of the operation |
08-09-2021, 18:31 | #3 (permalink) |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Second Option: You should re-flash the device with different firmwares one by one and check, whether modem is correct (not Unknown). If after writing of all firmwares, which You have, problem remains the same - most likely, this is HW problem (problem with eMMC flash chip). Steps to try to rebuild the EFS folder with a merge file: 1. The first thing is to have our phone with imei at 0000000 or Unknown 2. Root, and activate in addition to USB Debugging the OEM Unlock 3. Once the root is done we proceed to install a Root Explorer and access the EFS folder and we are going to eliminate all the content except the folders "FactoryApp" and "prov_data" and we turn off the phone. 4. The next step will be to flash via Odin with the Factory_Binary (Combination File) of the model to work with. 5. Once the Restart is done, press the "IME" button and a keyboard will appear with which we proceed. to verify the IMEI with * # 06 # and we will see that our imei is already correct again 6. We proceed to flash with a Stock Rom and this is it, IMEI Recovered and ready to continue working. |
The Following User Says Thank You to gcceleghg For This Useful Post: |
