06-23-2020, 17:04 | #1 (permalink) |
Banned Join Date: Apr 2014 Location: FUTURE
Member: 2171001 Status: Offline Thanks Meter: 196 | J730G U12 repair i imei failed i have j730g u12 repair imei failed warrenty void 1 Chimera Mobile Phone Utility version: 25.18.1333 @ ٢٠٢٠-٠٦-٢٣ Printing phone history Repair IMEI 02/11/41 11:49:31 ص Repair IMEI 02/11/41 10:57:19 ص Repair IMEI 02/11/41 10:54:00 ص Repair IMEI 02/11/41 10:52:35 ص Repair IMEI 02/11/41 10:50:37 ص Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-J730G Sales Code: TPA Country Code: PANAMA Timezone: Asia/Damascus Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri May 15 14:44:38 KST 2020 PDA Version: J730GUBSCCTE2 [may 2020, rev2] Phone Version: J730GUBSCCTE2 [may 2020, rev2] CSC Version: J730GUUBCCTE2 [may 2020, rev2] Product Code: TPA HIDSw Version: J730GUBSCCTE2/J730GUUBCCTE2/J730GUBSCCTE2/J730GUBSCCTE2 Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58K31SJ10X Imei: 356202093048546 Unique Number: CBJ0091985E7B15 Connections: AT,MTP Battery Status: 3.90V (39%) Network Type: GSM SIM Status: LOADED,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-05-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Trying on port SAMSUNG Mobile USB Serial Port (COM308) There is no proper diag port or not responding or the warranty is void Repair imei failed. Finished at local time: [٠٦.٢٣.٢٠ ١٩:٠١:٠٤] WorkID: 98718906 try flash complete stock firmware still failed also no pacth cert june 2020 we need it thanx |
The Following User Says Thank You to sam_alshahba For This Useful Post: |
09-04-2020, 14:27 | #4 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2669142 Status: Offline Thanks Meter: 0 | PDA Version: J730GUBSCCTE2 [may 2020, rev2] Phone Version: J730GUBSCCTE2 [may 2020, rev2] CSC Version: J730GUUBCCTE2 [may 2020, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: R58K42HBG1N Imei: 356202093471805 Imei2: 358202056952179 Battery Status: 3.80V (5%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unsupported modem. Install another firmware and try again. Finished at local time: [09.04.20 14:18:17] WorkID: 106223676 |
09-07-2020, 10:56 | #5 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,658 | reply Yes sadly that modem version is not supported yet. WE try to update it ASAP. Quote:
06-10-2021, 17:10 | #7 (permalink) | |
Junior Member Join Date: Feb 2009
Member: 962217 Status: Offline Sonork: drphone Thanks Meter: 1 | Quote:
Model: SM-J730G Sales Code: DOO Country Code: DOMINICAN REPUBLIC Timezone: America/New_York Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Fri May 15 14:44:38 KST 2020 PDA Version: J730GUBSCCTE2 [may 2020, rev2] Phone Version: J730GUBSCCTE2 [may 2020, rev2] CSC Version: J730GUUBCCTE2 [may 2020, rev2] Board Platform: EXYNOS5 Modem Platform: SHANNON315 Serial Number: RF8K8367QBL Imei: 3571xxxxxxxxxxxx Imei2: 000000000000000 Battery Status: 3.75V (43%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-05-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. | |
The Following User Says Thank You to electrom001 For This Useful Post: |
06-11-2021, 09:33 | #8 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,658 | reply Dear electrom001, Thank you for the feedback! Best regards Sab Chimera team Quote:
