Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 05-09-2022, 11:20   #1 (permalink)
Member: 154346
Thanks Meter: 37
JNY-LX1 remove huawei id
is suported from chimera or no bcos im try always failed.
work id-179401360
Old 05-09-2022, 11:43   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,709
reply
Dear Klodi,
Yes, it is supported by the Chimera Tool.
However, The phone is not in the right mode.
Please put the phone into factory mode via Hardware Test-Point! If you use Harmony cable please reconnect the cable at computer side.
Best regards
Sab
Chimera team
work id-179401360
Old 05-09-2022, 12:09   #3 (permalink)
Member: 154346
Thanks Meter: 37
i use harmony cable and reconect in factory mode with testpoint but not work.
Old 05-09-2022, 12:53   #4 (permalink)
Member: 154346
Thanks Meter: 37
WorkID: 179415299 CAN YOU HELP ME WITH MORE INFO
Old 05-09-2022, 13:23   #5 (permalink)
Member: 1787203
reply
Dear User,
Thank you for the quick reply. Does the Factory reset start during the process? If yes, please restart the phone and check if the ID is still on it or not. In some cases, we report false-negative results.
Best regards
Sab
Chimera team
Old 05-09-2022, 13:30   #6 (permalink)
Member: 154346
Thanks Meter: 37
not start the erase of the phone and id not removed
Old 05-09-2022, 15:16   #7 (permalink)
Member: 1787203
reply
Dear User,
The main problem is that the Factory reset does not start. Please do the ID remove again, then run the Factory Reset manually. Then check the phone.
Please update us, with the result of the process.
Best regards
Sab
Chimera team
Old 05-10-2022, 09:40   #8 (permalink)
Member: 154346
Thanks Meter: 37
i did that but same result . id not removed.
Old 05-10-2022, 10:18   #9 (permalink)
Member: 1787203
reply
Dear Klodi,
Please do the ID REMOVE service once again. However, when the process ends, do not reboot the device, instead, immediately run the FACTORY RESET manually.
After that, the Lock should be removed from the phone.
Best regards
Sab
Chimera team
Old 06-08-2022, 13:44   #10 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks Meter: 145
[QUOTE=Chimera Tool;14554268]Dear Klodi,
After this procedure huaei id remove sucess.
Old 08-05-2023, 07:29   #11 (permalink)
Member: 2497406
Sonork: 100.1672478
Thanks Meter: 50
jln-lx1 huawei id remove chimera plz add
Checking fastboot device.....OK
Reading info.....OK
Device Model: JLN-LX1
Device Firmware: JLN-L21 12.0.1.189(C185E8R1P2)
Base Firmware: JLN-LGRP2-OVS 102.0.1.189
Custom Firmware: JLN-L21-CUST 102.0.1.8(C185)
Preload Firmware: JLN-L21-PRELOAD 102.0.1.2(C185R1)
Device FB Lock: LOCKED
Device USER Lock: LOCKED
Device Lock: INFO locked
Operation {Read info} ID: 08F70611EBF1B021
Elapsed time 00:00 -- Version 4.5.1 Build 002
Old 08-07-2023, 12:09   #12 (permalink)
Member: 1787203
Dear User,
We will try to add this model for ID Removal, soon.
Best Regards,
ChimeraTeam
Reading info.....OK
Page generated in 0.22111 seconds with 8 queries
