03-01-2021, 11:37 | #1 (permalink) |
No Life Poster Join Date: Feb 2009 Location: CMB/Ceylon
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | JNY-LX2 Huwaei id remove fail Gathering information... Device Model: JNY-LX2 Current software version: JNY-L22 10.1.0.298(C636E1R4P1) Hardware version: Ver3.0 Boot info: locked Image check: secure image verify success Android version: 10 Battery state: 3779mv Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.7 Phone info: (bootloader) main version do not exist in oeminfo! VendorCountry: hw/spcseas Base version: JNY-LGRP2-OVS 10.1.0.298 Cust version: JNY-L22-CUST 10.1.0.1(C636) Preload version: JNY-L22-PRELOAD 10.1.0.1(C636R4) Finished at local time: [03.01.21 16:07:30] WorkID: 126505282 |
03-01-2021, 11:48 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Hi there, We checked the work, but it do not failed. The process received a Cancel request from the client. What happened exactly? Best regards Sab Quote:
03-02-2021, 07:02 | #5 (permalink) |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Rebooting phone to USB update mode Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished We counld't identify the device, please select manually, if present! Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. Finished at local time: [03.02.21 11:27:44] WorkID: 126610008 but id still remains |
03-02-2021, 10:42 | #6 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Hello, After the ID REMOVE service, the Factory reset automatically starts? IF yes, then good, that is part is working well. Now after that, you have to try to set up the device in offline mode. Best regards Sab Quote:
03-02-2021, 13:07 | #7 (permalink) | |
Member: 962029 Status: Offline Sonork: OEM Lock : ON Thanks Meter: 4,126 | Quote:
yes factory reset done but cant setup in offline mode..its need wifi connection to continue | |
