Lg k22 frp HI I REMOVED FRP BY CHIMERA,BUT PHONE IS SITLL ASKING FOR GMAIL Chimera Mobile Phone Utility version: 29.75.1447 @ 2021-09-24 Printing phone history FRP Remove 2021-09-24 17:58 Removing factory reset protection... Removing frp lock... Successfully finished. Finished at local time: [09.24.21 20:23:24] WorkID: 151795122 |
reply Dear User, Thank you for the report. We checked your works, but as we saw you performed the method again successfully. The device is workable now? Best regards Sab Chimera Team Quote:
i tried one more time but not succeed. and this a new phone k30 not succed.chimera removes frp but phone sitll ask for gmail Chimera Mobile Phone Utility version: 29.80.1209 @ 2021-09-28 Printing phone history FRP Remove 2021-09-25 18:14 Removing factory reset protection... Trying to boot the phone into download mode... Phone detected. Removing frp lock... Successfully finished. Finished at local time: [09.28.21 13:59:21] WorkID: 152232817 |
reply Dear User, Thank you for the feedback. We received a few reports regarding to this problem. What we can recommend is to reflash the device, and then repeat the FRP RESET. In many cases, it will solve the problem. Please report back the result. Best regards Sab Chimera Team Quote:
hi i could not flash this mobile FRP Remove 2021-09-28 11:59 FRP Remove 2021-09-25 18:14 Firmware Update started Downloading firmware... Firmware downloaded successfully Preparing firmware files... Firmware extraction Warning! The following model name mismatch(es) detected: This phones model name is LM-X320EMW, while this firmware is for model LG-LMX320EMW according to the firmware server. This phones model name is LM-X320EMW, while this firmware is for model LG-X320 according to the DZ file (X32020i_00_user-signed-ARB0_OPEN_EU_DS_OP_0722.dz). Flashing a firmware on the phone that is not made for this model can cause brick! Do you want to continue? The procedure has been canceled. Finished at local time: [09.28.21 18:01:52] WorkID: 152270276 |
and I have the same promlema , no flashing , no frp. Firmware extraction Warning! The following model name mismatch(es) detected: This phones model name is LM-G910EMW, while this firmware is for model LG-LMG910EMW according to the firmware server. This phones model name is LM-G910EMW, while this firmware is for model LG-G910 according to the DZ file (G91020a_00_user-signed-ARB0_COM1_EU_OP_0810.dz). Flashing a firmware on the phone that is not made for this model can cause brick! Do you want to continue? Changing to download mode ... Flashing firmware... USB Connection Established Retrying... Phone detected. Firmware initialization error Finished at local time: [09.28.21 20:50:12] WorkID: 152296184 |
Dear Users, Yes, the problem comes from the firmware version. We will check the logs based on your works, hopefully, we can find something which can and will help our work to develop a new method for the LG FRP service. Best regards Sab Chimera team |
Hello Chimera Team, having the same problem with LG LM-K200QM (K32). Chimera says the process is complete, but device is still asking for account. Chimera Mobile Phone Utility version: 32.69.1353 @ 2022-07-26 Printing phone history FRP Remove 26/07/2022 9:52 PM FRP Remove 26/07/2022 9:46 PM Removing factory reset protection... Trying to boot the phone into download mode... Phone detected. Removing frp lock... Successfully finished. Finished at local time: [07.26.22 17:18:28] WorkID: 189165688 Quote:
reply Dear Jazz, Thank you for the report, yes, we noticed the issues with the FRP. Currently our team is working on the solution, it could be that we will remove the FRP reset from various LG models until we can upgrade the service. Best regards Sab Chimera team Quote:
I tried also with another LG ZN-FM150 (M151) and same result - FRP still there. |
reply Dear Jazz, Sure, we will save that as well. I hope that soon we can do some changes in the method so you guys can do the service without any trouble. Best regards Sab Chimera team Quote:
