01-12-2022, 23:09 | #1 (permalink) |
No Life Poster Join Date: Apr 2006 Location: On Earth
Member: 266339 Status: Offline Thanks Meter: 99 | LG Velvet LM-G910EMW frp reset fails I have one LG Velvet that i frp unlock, server said many times it has been successfully unlocked. But the phone is still locked. Is there any step I do not follow? Phoen has Software:G910EMW10c. I will try a downgrade as soon as i get a firmware Any Idea? Thanks Last edited by benarmand; 01-12-2022 at 23:09. Reason: Here are some work IDs: WorkID: 165756994 and WorkID: 165758749 |
01-13-2022, 10:40 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 24,090 | reply Dear User, Yes, the firmware flashing could solve the issue. WE would recommend to check the following sources for the Firmware: https://support.halabtech.com https://firmware.gem-flash.com Home Page | Romthai Center https://easy-firmware.com https://androidhost.ru https://androidfilehost.com https://gsmhostingfiles.com http://5grom.cn http://bbs.lophone.cn Best regards Sab Chimera team Quote:
03-23-2023, 10:47 | #4 (permalink) |
Freak Poster Join Date: Nov 2007 Location: cape town
Member: 624019 Status: Offline Sonork: 1650290 Thanks Meter: 10 | Chimera team please need your help LG-VELVET FRP Chimera Mobile Phone Utility version: 35.15.1443 @ 2023-03-23 Printing phone history Reboot into normal mode 3/23/2023 9:36 AM FRP Remove 3/23/2023 9:26 AM Removing factory reset protection... Removing frp lock... Command execution was denied: Try reverting your firmware to an earlier version! Finished at local time: [03.23.23 11:43:03] WorkID: 216036015 |
03-23-2023, 14:03 | #5 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 24,090 | reply Dear User, In that case, you have to try to reflash the device with an Older Firmware and just after that try to repeat the same FRP RESET method with the Chimera tool. The firmware flashing can be done via Firmware Update method. Most of our clients are using this Software version - G910EMW10l Best regards Sab Chimera team Quote:
