09-14-2021, 16:43 | #2 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, The Tool provides you a guide for it. If that is not workable, then please reinstall the Chimera Tool LG driver (you can do it in the Settings), then replug the phone to the tool and select the MTP or the LG Sofware connection type. Then repeat the service. Best regards Sab Chimera Team |
09-14-2021, 17:27 | #3 (permalink) |
No Life Poster Join Date: Sep 2009 Location: 9ja
Member: 1110430 Status: Offline Thanks Meter: 104 | The phone is connected normally but in the process of unlocking the chimera asking for the port check test.So i need the code to enable port check test on the phone |
09-15-2021, 14:18 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,741 | reply Dear User, Sadly in that case we cannot do much. Generally, these codes should provide you the Port Check test, but in some case, the device does not have this option. I would recommend checking other forums as well for this port check test. Maybe there is a model-specific method/workaround. Best regards Sab Chimera Team |
