03-14-2017, 14:52 | #3 (permalink) |
No Life Poster Join Date: Jun 2005 Location: Sydney
Member: 153695 Status: Offline Sonork: srkhan Thanks Meter: 788 | Reset Screen Lock 3/14/2017 12:10:33 PM Reset FRP Lock 3/14/2017 11:31:35 AM SW Change 3/14/2017 11:24:21 AM SW Change 3/14/2017 11:16:40 AM Firmware Compatibility 3/14/2017 10:55:13 AM [Reset screen lock started] Selected model: SM-N9208 Checking custom root image... Present. Rooting by custom image based root method... Flashing firmware... Waiting for download mode. Model mismatch: selected: SM-N9208, present: SM-N9208DX. Connect the correct model! |
03-14-2017, 15:16 | #4 (permalink) |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Samsung Galaxy Note 5 Model: SM-N9208 Supported features ✓ SW Change ✓ Unlock ✓ Read Codes ✓ Repair IMEI ✓ Info ✓ Root / Unroot ✓ Read / Write certificate ✓ Restore / Store backup ✓ Reset FRP Lock ✓ Reset Reactivation Lock ✓ Repair EFS ✓ Reset Screen Lock ✓ Reset FRP Lock ✓ Firmware Compatibility ✓ Reset FRP / Reactivation Lock ✓ Reset Screen Lock ✓ Patch Certificate The N9208DX is not supported. https://chimeratool.com/en/models |
The Following User Says Thank You to gcceleghg For This Useful Post: |
03-14-2017, 15:36 | #5 (permalink) | |
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
-Download and flash combination file through odin https://www.androidfilehost.com/?w=search&s=n9208dx -This will enable adb. Run the command to bypass activation Adb shell content insert --url content: // settings / secure --bind name: s: user_setup_complete --bind value: s: 1 - Turn on oem unlocking - Reset the phone with phone menu. - But you need the last firmware to flash again....... If you have Z3X: Done by z3x select N9200 for n9208dx | |
