01-16-2015, 17:25 | #1 (permalink) |
No Life Poster Join Date: Aug 2011 Location: caribbean island
Member: 1643797 Status: Offline Thanks Meter: 183 | repair network fail Printing phone history Network repair 2015-01-16 16:23:02 ERROR Network repair 2015-01-16 16:22:52 ERROR Info 2015-01-16 16:21:02 FINISHED Network repair 2015-01-16 16:20:14 ERROR Network repair 2015-01-16 16:19:46 ERROR [Repair Qualcomm modem filesystem.] File: ChimeraFiles/Samsung/Qualcomm/SGH-I337/SGH-I337_from_server.cqcn Connecting to phone. On dial window enter *#0808# (or *#9090# or *#7284#) and set DM + MODEM + ADB 2. Select OK on phone display Phone found at COM486. Gathering qcn filesystem informations. Serial port init failed. Finished at local time: [01.16.15 11:24:16] WorkID: 3730763 |
01-16-2015, 18:27 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear lucky999, Soon we will have another update which will contain a bugfix for this problem. After ChimeraTool was refreshed please try again. If still problem, please let us know. Best Regards, Chimera Team Quote:
01-16-2015, 20:37 | #3 (permalink) |
No Life Poster Join Date: Nov 2005 Location: ABouSHaDy Age: 48
Member: 200717 Status: Offline Sonork: 100.1580056 Thanks Meter: 793 | repair network fail Printing phone history Network repair 2015-01-16 19:29:42 ERROR Network repair 2015-01-16 19:26:41 ERROR Network repair 2015-01-16 19:24:43 ERROR Info 2015-01-16 19:24:22 FINISHED Network repair 2015-01-16 19:23:45 ERROR [Repair Qualcomm modem filesystem.] File: ChimeraFiles/Samsung/Qualcomm/SGH-I337/SGH-I337_from_server.cqcn Connecting to phone. On dial window enter *#0808# (or *#9090# or *#7284#) and set DM + MODEM + ADB 2. Select OK on phone display Phone found at COM71. Gathering qcn filesystem informations. Be patient! Do NOT disconnect the phone! Could not write nv items: access denied! (SPC auth failed) Finished at local time: [01.16.15 20:35:59] WorkID: 3734107 |
02-10-2015, 23:32 | #4 (permalink) |
No Life Poster Join Date: Oct 2006 Location: USA
Member: 362515 Status: Offline Sonork: 100.1590585 Thanks Meter: 160 | Chimera Mobile Phone Utility version: 5.58.1223 @ 2015-02-11 Printing phone history Info 2015-02-10 21:02:30 FINISHED Network repair 2015-02-10 21:01:36 ERROR Network repair 2015-02-10 21:00:53 ERROR [Repair Qualcomm modem filesystem.] File: ChimeraFiles/Samsung/Qualcomm/SM-N9005/SM-N9005_from_server.cqcn Connecting to phone. 1.On dial window enter *#0808# (or *#9090# or *#7284#) and set DM + MODEM + ADB 2. Select OK on phone display Try to connect: COM31 Be patient! Do NOT disconnect the phone! Try to connect: COM32 Be patient! Do NOT disconnect the phone! Could not connect to phone(SPC auth failed). Finished at local time: [02.11.15 01:30:11] WorkID: 4040683 |
02-11-2015, 11:48 | #5 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear @matrix@, Exactly what is wrong with your phone? Best Regards, Chimera Team Quote:
04-29-2015, 18:47 | #6 (permalink) |
Junior Member Join Date: Nov 2014
Member: 2300399 Status: Offline Thanks Meter: 0 | help Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-C105 Android Version: 4.2.2 Sales Code: XSA PDA Version: C105XXUAMK7 [november 2013, rev7] Phone Version: C105XXUAMHC [august 2013, revC] CSC Version: C105XSAAMK2 [november 2013, rev2] Product Code: SM-C1050ZWAXSA HIDSw Version: C105XXUAMK7/C105XSAAMK2/C105XXUAMHC/C105XXUAMK7 Board Platform: EXYNOS4 Serial Number: CN1F600JGJL Imei: Unique Number: CM800CB6297DD51 Connections: AT,MTP Battery Status: 3.75V (36%) Network Type: GSM SIM Status: ABSENT Checking root state. done. Completado. Repairing imei ... Try to connect: COM47 Be patient! Do NOT disconnect the phone! Could not connect to phone(SPC auth failed). Finished at local time: [04.29.15 13:09:41] WorkID: 4897812 |
04-30-2015, 08:25 | #7 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,787 | reply Dear Gus0tavo, SPC Auth failed error means that this phone's default SPC code was modified before with some 3rd Party Tool. By this problem, ChimeraTool can not use the default SPC code, so this procedure for this phone will not work unfortunately. Best Regards, Chimera Team Quote:
07-29-2015, 22:00 | #10 (permalink) |
Major Poster Join Date: Jun 2009 Location: Malawi
Member: 1064767 Status: Offline Thanks Meter: 7 | Hi i order for DM+Modem+ADB to work on lollipop, you need to got to recovery mood and enable cp logging, reboot and try it again. |
The Following User Says Thank You to nmpeka For This Useful Post: |
06-15-2020, 10:34 | #11 (permalink) |
Freak Poster Join Date: May 2016 Location: MOZAMBIQUE
Member: 2576731 Status: Offline Thanks Meter: 72 | p9 imei repair pl fix this Chimera Mobile Phone Utility version: 25.07.1137 @ 2020-06-15 Printing phone history Repair IMEI 6/15/2020 9:26:57 AM Repair IMEI 6/15/2020 9:22:02 AM Repair IMEI 6/15/2020 9:17:39 AM Repair IMEI 6/15/2020 9:16:47 AM Repairing IMEI(s)... Factory reset notify window was accepted. Searching for manufacture port... Serial port init failed. Finished at local time: [06.15.20 11:32:24] WorkID: 97961443 |
