10-29-2020, 01:31 | #1 (permalink) |
Freak Poster Join Date: Sep 2014
Member: 2253202 Status: Offline Thanks Meter: 32 | N975F U6 IMEI REPAIRED&PATCHED HELP? BOOTLOGO FIX file Printing phone history SW Change 10/28/2020 11:25 PM Repair IMEI 10/28/2020 11:23 PM Repair IMEI 10/28/2020 11:21 PM Repair IMEI 10/28/2020 4:42 PM Get Info 10/28/2020 4:39 PM Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N975F Carrier ID: XFV Sales Code: AUT Country Code: Switzerland Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jul 28 08:56:26 KST 2020 PDA Version: N975FXXU6CTGD [july 2020, revD] Phone Version: N975FXXS6CTGA [july 2020, revA] CSC Version: N975FOXM6CTG8 [july 2020, rev8] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8M74JDWMF Imei: 000000000000000 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 000000000000000 Repaired imei: 355644637736766 Current imei2: 000000000000000 Repaired imei2: 353564576486987 Successfully finished. Finished at local time: [10.29.20 01:44:36] WorkID: 113195908 Chimera Mobile Phone Utility version: 26.44.1045 @ 2020-10-29 Printing phone history Patch Certificate 10/28/2020 11:48 PM Patch Certificate 10/28/2020 11:47 PM Patch Certificate 10/28/2020 11:47 PM Repair IMEI 10/28/2020 11:41 PM SW Change 10/28/2020 11:25 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N975F Carrier ID: XFV Sales Code: AUT Country Code: Switzerland Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jul 28 08:56:26 KST 2020 PDA Version: N975FXXU6CTGD [july 2020, revD] Phone Version: N975FXXS6CTGA [july 2020, revA] CSC Version: N975FOXM6CTG8 [july 2020, rev8] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8M74JDWMF Imei: 355644637736766 Imei2: 353564576486987 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.29.20 01:50:06] WorkID: 113196466 |
10-29-2020, 10:27 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,661 | reply Hello! As we see the services finished with a successfully done message. Please explain the problem that you have with the phone? Quote:
10-29-2020, 15:35 | #6 (permalink) |
Member: 2253202 Status: Offline Thanks Meter: 32 | atch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N975F Carrier ID: XFV Sales Code: AUT Country Code: Switzerland Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Jul 28 08:56:26 KST 2020 PDA Version: N975FXXU6CTGD [july 2020, revD] Phone Version: N975FXXS6CTGA [july 2020, revA] CSC Version: N975FOXM6CTG8 [july 2020, rev8] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8M74JDWMF Imei: 355644637736766 Imei2: 353564576486987 Network Type: GSM SIM Status: LOADED,UNKNOWN Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-08-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Previously installed patchcert detected. Previously installed patchcert successfully removed. Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [10.29.20 16:28:05] WorkID: 113269163 STILL THE SAME |
