07-10-2023, 00:57 | #1 (permalink) |
Junior Member Join Date: May 2008 Location: mexico
Member: 778167 Status: Offline Thanks Meter: 3 | a346m u2 after repair imei network locke for all carriers |
The Following User Says Thank You to neonico2 For This Useful Post: |
07-10-2023, 09:46 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,752 | Dear User, As fasr as I know, this is not possible as the IMEI Repair does not change the network settings. You can try to unlock it on the repaired imei, we have an unlock solution on it based on the carrier of the phone. Currently, we do not have any other suggestions. Best Regards, ChimeraTeam Quote:
07-11-2023, 18:34 | #3 (permalink) |
Member: 778167 Status: Offline Thanks Meter: 3 | a346m-u2-after-repair-imei-network-locke-all-carriers this is the log with the original nvdata, nvram and original imei Model: SM-A346M Carrier ID: MXO Sales Code: MXO Country Code: Mexico Timezone: America/New_York Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Fri Apr 7 07:38:18 KST 2023 PDA Version: A346MUBS2AWD2 [april 2023, rev2] Phone Version: A346MUBS2AWD2 [april 2023, rev2] CSC Version: A346MOWO2AWD2 [april 2023, rev2] Board Platform: MT6877 Modem Platform: MT6877 Imei: 351123901071832 Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2023-04-01 Em Did: 20B5849A3787E811 Bootrom commands disabled: no Successfully finished. Finished at local time: [07.11.23 10:47:19] WorkID: 226719676 and this is the log with the imei repaired and patched cert Model: SM-A346M Carrier ID: MXO Sales Code: MXO Country Code: Mexico Timezone: America/New_York Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Fri Apr 7 07:38:18 KST 2023 PDA Version: A346MUBS2AWD2 [april 2023, rev2] Phone Version: A346MUBS2AWD2 [april 2023, rev2] CSC Version: A346MOWO2AWD2 [april 2023, rev2] Board Platform: MT6877 Modem Platform: MT6877 Imei: 368900436354234 Network Type: GSM SIM Status: NETWORK_LOCKED Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2023-04-01 Em Did: 20B5849A3787E811 Bootrom commands disabled: no Successfully finished. Finished at local time: [07.11.23 11:29:55] WorkID: 226724812 if you see the sim status say in the first log, loaded, and when i repaired and cert patched in the last log network locked, the device are unlocked, but blacklisted, and now even with the original sim say network locked. i can submit the original nvdata nv ram backup and the repaired too if you want to check that issue |
07-12-2023, 11:30 | #4 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,752 | Dear User, In your first Get Info work, the Sim status was locked. Workid: 226718903 The IMEI Repair procedure should not change the network lock status. Best Regards, ChimeraTeam Quote:
04-08-2024, 01:08 | #5 (permalink) |
Insane Poster Join Date: May 2018 Location: havanav
Member: 2833796 Status: Offline Thanks Meter: 6 | Hello, have we solved this? I also did imei repair on an A336M from telcel mexico. Simcard working fine, and now is NETWORK LOCKED. With no possibility of reading codes. Any help would be appreciated. Thanks WORKID: 269000507 user: luisito9201 |
04-08-2024, 09:33 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,752 | Dear User, Why aren't you able to read the codes from the device? This phone was network locked before, as soon it connected to the network, you saw that it is locked. Best Regards, ChimeraTeam |
04-08-2024, 15:29 | #7 (permalink) |
Member: 2833796 Status: Offline Thanks Meter: 6 | Dear support: Thanks for the reply. Let me explain a little better. Before imei repair, phone was working fine, with network and signal 4g/3g/2g. After imei repair, in the botton of the screena theres a message: LOCKED FOR NETWORK. When you unlock the screen, theres no possibility of entering any network unlock codes. I did test and restored the previous state of nvdata. Phone working fine with signal, NOT locked to network. Sorry for my bad english, I hope you understand. |
04-09-2024, 12:26 | #8 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,752 | Dear User, Telcel uses a mdm-based network lock on many of their newer devices. When it connects to internet, it will communicate with servers and lock up. We would recommend attempting to unlock bootloader, and flash a patched rom that disables knoxguard and mdm.,this should disable the network lock too. Best Regards, ChimeraTeam Quote:
