11-09-2021, 16:20 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | [Complete][Guide] S10 G973F ”U10” Android 11 ROOT / IMXX & Network Repair Done ROOT WITH MAGISK 2012 subaru wrx sti 0 60 Chimera Mobile Phone Utility version: 30.17.1048 @ 2021-11-09 Printing phone history Reboot 2021/11/09 13:29 Repair started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Carrier ID: XFA Sales Code: ARO Country Code: Argentina Timezone: Africa/Johannesburg Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Tue Aug 10 15:38:35 KST 2021 PDA Version: G973FXXUCFUH3 [august 2021, rev3] Phone Version: G973FXXUCFUH3 [august 2021, rev3] CSC Version: G973FOWOCFUH3 [august 2021, rev3] Product Code: ARO HIDSw Version: G973FXXUCFUH3/G973FOWOCFUH3/G973FXXUCFUH3/G973FXXUCFUH3 Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RF8N300Y2KY Imei: 354127112986172 Connections: AT,MTP Battery Status: 3.93V (65%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-08-01 Em Did: 202A364DB5498011 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Current imei: 35 Repaired imei: 35 Current imei2: 35 Repaired imei2: 35 Successfully finished. Finished at local time: [11.09.21 15:34:27] WorkID: 157503811 Chimera Mobile Phone Utility version: 30.17.1048 @ 2021-11-09 Printing phone history Reboot 2021/11/09 13:44 Repair IMEI 2021/11/09 13:40 Reboot 2021/11/09 13:39 Repair IMEI 2021/11/09 13:33 Reboot 2021/11/09 13:29 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G973F Carrier ID: XFA Sales Code: ARO Country Code: Argentina Timezone: Africa/Johannesburg Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Tue Aug 10 15:38:35 KST 2021 PDA Version: G973FXXUCFUH3 [august 2021, rev3] Phone Version: G973FXXUCFUH3 [august 2021, rev3] CSC Version: G973FOWOCFUH3 [august 2021, rev3] Product Code: ARO HIDSw Version: G973FXXUCFUH3/G973FOWOCFUH3/G973FXXUCFUH3/G973FXXUCFUH3 Board Platform: UNIVERSAL9820 Modem Platform: SHANNON5000 Serial Number: RF8N300Y2KY Imei: 35 Connections: AT,MTP Battery Status: 3.88V (63%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2021-08-01 Em Did: 202A364DB5498011 Preparing... Checking root access. The phone is rooted by: 23.0:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.09.21 15:45:45] WorkID: 157505627 |
The Following User Says Thank You to ..::GMSR::.. For This Useful Post: |
11-10-2021, 10:31 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,667 | reply Dear GMSR, Thank you for the detailed report and for the linked video. Very good job from you. Best regards Sab Chimera team Quote:
05-23-2023, 13:29 | #3 (permalink) | ||
Freak Poster Join Date: Oct 2009 Location: IND TO RSA.
Member: 1143337 Status: Offline Thanks Meter: 104 | Hi chimera team today im trying same all this but not working i try auto-root with chimera no luck even try with MAGISK patch root no luck any other solution please Quote:
05-24-2023, 08:25 | #5 (permalink) | |
Member: 1143337 Status: Offline Thanks Meter: 104 | Quote:
yes its already unlocked without BT unlock root not possible you can see sir (The phone is rooted by: 26.1:MAGISKSU) (Autoroot succeeded.) | |
