02-25-2021, 14:08 | #1 (permalink) |
Freak Poster Join Date: May 2016
Member: 2573102 Status: Offline Thanks Meter: 21 | New version throws an Error (unable to patch cert) on Converted Dual sim models! Printing phone history Patch Certificate 2021-02-25 12:39 PM Patch Certificate 2021-02-25 12:38 PM Patch Certificate 2021-02-25 12:38 PM Patch Certificate 2021-02-25 12:37 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N950F Carrier ID: LUC Sales Code: PAK Country Code: PAKISTAN Timezone: Asia/Karachi Android Version: 8.0.0 [R16NW] [SDK 26] Build Date: Mon Jul 9 15:43:26 KST 2018 PDA Version: N950FXXU4CRG3 [july 2018, rev3] Phone Version: N950NKOU5DSJ1 [october 2019, rev1] CSC Version: N950FOXM4CRG3 [july 2018, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON355 Serial Number: R39JC07QFV Imei: 359735080099136 Imei2: 359735080099144 Battery Status: 4.00V (60%) Network Type: GSM SIM Status: READY,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2018-07-01 Preparing... Checking root access. The phone is rooted by: 20.1:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unable to patch certificate. Finished at local time: [02.25.21 18:00:47] WorkID: 126151231 Tested on (N960n) (N950N) before the update patch cert was working after update Not working! plz fix it! |
02-25-2021, 16:45 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,733 | reply Dear User, Thank you for the report that you made. Can you please update the device firmware and then do the process again? We would like to see the result of that. Best regards Sab Quote:
02-26-2021, 07:38 | #3 (permalink) | |
Member: 2573102 Status: Offline Thanks Meter: 21 | N960N with same Error Android version 9! Quote:
Chimera Mobile Phone Utility version: 27.59.1025 @ 2021-02-21 Printing phone history Patch Certificate 2021-02-21 8:30 AM Patch Certificate 2021-02-21 7:08 AM Patch Certificate 2021-02-21 7:07 AM Patch Certificate 2021-02-21 7:06 AM Patch Certificate 2021-02-21 7:04 AM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N960F Carrier ID: KTC Sales Code: SKC Country Code: KOREA Timezone: Asia/Karachi Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Tue Oct 22 20:52:02 KST 2019 PDA Version: N960FXXS4CSJ1 [october 2019, rev1] Phone Version: N960NKOU3CSG1 [july 2019, rev1] CSC Version: N960NOKR3CSG3 [july 2019, rev3] Board Platform: EXYNOS5 Modem Platform: SHANNON360 Serial Number: R39KA09V6N Imei: 863224031015094 Imei2: 863224031015029 Battery Status: 3.97V (90%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2019-11-01 Preparing... Checking root access. The phone is rooted by: 21.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Unable to patch certificate. Finished at local time: [02.21.21 13:31:25] WorkID: 125668276 | |
02-26-2021, 11:03 | #4 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,733 | reply Hi there, Please update the device with the following one: N960FXXU4DSLB [december 2019, revB] As we see you used a combination FW. We would recommend to use Stock, official Firmware's for the Patch cert / IMEI Repair. Best regards Sab Quote:
02-27-2021, 06:27 | #5 (permalink) | |
Member: 2573102 Status: Offline Thanks Meter: 21 | Quote:
same model with same firmware version on (with 2019 patch cert) that's why i'm here and reporting the issue! thnax! | |
03-01-2021, 12:53 | #6 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,733 | reply Hello, We will report the problem to the dev's. As we see with combination files, we have to do more works. We do support the Stock firmware's currently. Best regards Sab Quote:
