10-12-2021, 12:40 | #1 (permalink) |
Freak Poster Join Date: Dec 2017
Member: 2792776 Status: Offline Sonork: 1577835 Thanks Meter: 82 | Sea-al10 huawei id not done Device Model: SEA-AL10 Current software version: SEA-AL10 11.0.0.143(C00E128R1P1) Hardware version: Ver3.0 Boot info: locked Image check: secure image verify fail Android version: 10 Battery state: 3925mv Key version: huawei_key_v1 Root info: SAFE Rescue version: rescue0.8 Phone info: NO MAIN VERSION VendorCountry: all/cn Base version: SEA-LGRP3-CHN 11.0.0.143 Cust version: SEA-AL10-CUST 11.0.0.128(C00) Preload version: SEA-AL10-PRELOAD 11.0.0.1(C00R1) Finished at local time: [10.12.21 16:36:51] WorkID: 154004431 Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [10.12.21 16:41:23] WorkID: 154004589 |
10-12-2021, 12:47 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,733 | reply Dear User, After the ID REMOVE service, please run a Factory Reset on the device. Without that, the method won't be completed. So make sure that you do that. If you did it, and the ID still remains on the phone, then please report it. Best regards Sab Chimera Team Quote:
10-12-2021, 14:10 | #3 (permalink) | |
Member: 2792776 Status: Offline Sonork: 1577835 Thanks Meter: 82 | Quote:
10-13-2021, 13:27 | #7 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,733 | reply Dear User, Please run the ID remove once again. If it is ready, please put the phone manually into recovery, and then, from there run the Factory Reset. At the end, the lock should be removed. Of course let us know the result! Best regards Sab Chimera team |
10-14-2021, 14:15 | #8 (permalink) | |
Printing phone history Huawei Id & Frp Remove 10/12/2021 11:36 AM Get Info 10/12/2021 11:35 AM Huawei Id & Frp Remove 10/12/2021 11:34 AM Read Cert 10/12/2021 8:33 AM Get Info 10/12/2021 8:33 AM Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished Uploading data Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [10.14.21 18:11:41] WorkID: 154292215 still not work | |
