11-01-2020, 10:28 | #1 (permalink) |
Crazy Poster Join Date: Apr 2018
Member: 2827626 Status: Offline Thanks Meter: 6 | note 10 plus ......N975f u6 patch done Printing phone history Patch Certificate 2020/11/1 8:44 Patch Certificate 2020/11/1 8:41 Repair IMEI 2020/11/1 8:38 Repair IMEI 2020/11/1 8:33 Repair IMEI 2020/11/1 7:55 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N975F Carrier ID: XME Sales Code: XME Country Code: MALAYSIA Timezone: Asia/Kuala_Lumpur Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Sep 17 19:50:24 KST 2020 PDA Version: N975FXXS6DTI5 [september 2020, rev5] Phone Version: N975FXXS6DTI5 [september 2020, rev5] CSC Version: N975FOXM6DTH7 [august 2020, rev7] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8MA0HJQ0P Imei: 351591119556994 Imei2: 351592119556976 Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [11.01.20 16:46:55] WorkID: 113635597 if u phone keep reboot ... Dun worry !!!! just press recovery and press reboot u phone after this .... let u phone searching network around 5min after this ..u phone is done when u restart the phone ..... u need take around 5min for searching just share ....... hope can help u all |
The Following User Says Thank You to gry2999 For This Useful Post: |
11-02-2020, 12:08 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,727 | reply Good day! Thank you for the detailed report / post. Quote:
02-26-2021, 13:00 | #3 (permalink) |
Junior Member Join Date: Apr 2013
Member: 1911137 Status: Offline Thanks Meter: 2 | helo for all n975f u6 patch cert done Model: SM-N975F Carrier ID: BTU Sales Code: BTU Country Code: UK & IRE Timezone: Asia/Karachi Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Sep 17 19:50:24 KST 2020 PDA Version: N975FXXS6DTI5 [september 2020, rev5] Phone Version: N975FXXS6DTI5 [september 2020, rev5] CSC Version: N975FOXM6DTH7 [august 2020, rev7] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8M82151JR Imei: 35xxxxxxxxxxxxxxx Imei2: 35xxxxxxxxxxxxxx Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. |
05-07-2021, 09:52 | #5 (permalink) |
Insane Poster Join Date: Oct 2019 Location: southafrica
Member: 2931678 Status: Offline Thanks Meter: 28 | Chimera Mobile Phone Utility version: 28.35.1256 @ 2021-05-07 Printing phone history Patch Certificate 07/05/2021 08:47 Repair IMEI 07/05/2021 08:44 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-N975F Carrier ID: XFV Sales Code: XFV Country Code: South Africa Timezone: Africa/Johannesburg Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Sep 17 19:50:24 KST 2020 PDA Version: N975FXXS6DTI5 [september 2020, rev5] Phone Version: N975FXXS6DTI5 [september 2020, rev5] CSC Version: N975FOXM6DTH7 [august 2020, rev7] Board Platform: UNIVERSAL9825 Modem Platform: SHANNON5000 Serial Number: RF8MA3JPCPD Imei: 35xxxxxxxxxxxxx Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-10-01 Em Did: 20230E2DC86B2611 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [05.07.21 01:49:00] WorkID: 133517163 |
05-07-2021, 11:10 | #6 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,727 | reply Thank you for the feedback! Quote:
