Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 01-02-2023, 22:09   #1 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 21,733
Cool ⭐️ OPPO Qcomm Dynamic FRP Remove ⭐️
Added a new FRP Remove solution for OPPO phones with Qualcomm SoCs. It's available from EDL mode.
We can't provide an exact supported model list, because it's a generic solution which utilises a custom feature of the Qualcomm programmers.
Based on our current programmer database we've collected a list of the supported SoCs below. Please note: this solution might not work on every device that is equipped with the listed SoCs.
  • Qualcomm Snapdragon 450
  • Qualcomm Snapdragon 460
  • Qualcomm Snapdragon 662
  • Qualcomm Snapdragon 680 4G
  • Qualcomm Snapdragon 720G
  • Qualcomm Snapdragon 750G
  • Qualcomm Snapdragon 765G
  • Qualcomm Snapdragon 865
  • Qualcomm Snapdragon 888
The new solution uses Oppo programmers from the official firmware packs, which are named like "prog_firehose_ddr_fwupdate.elf". If Chimera can't provide you a suitable programmer you can look inside a firmware pack and pick one manually. You can use Chimera's own Firmware Extractor (Utility) for this. Be aware that the procedure can take a long time to execute (10-15 minutes) and removing the phone during the process will make the phone unable to boot. This long process usually happens only once on a device.
You're welcome to post your experience and results in this thread. Please also share the model names for every successful procedure!
Software version: 34.41.1114
Release date: 2 January 2023
Visit our Webshop: https://chimeratool.com/shop
Like us on Facebook: https://www.facebook.com/chimeratool
Read our Help & Documentation: https://chimeratool.com/docs
Get Support: https://chimeratool.com/contact
GsmEasy Distributor: http://www.imei.us
GsmServer Distributor: http://www.gsmserver.com
The Following 10 Users Say Thank You to Chimera Tool For This Useful Post:
Old 01-02-2023, 22:40   #2 (permalink)
CrKdz13's Avatar
Member: 111121
Sonork: 100.99340 : CrKdz13
Thanks Meter: 483
This solution just for FRP or reset also may works ?
WBR
Old 01-02-2023, 22:43   #3 (permalink)
Member: 2878099
Thanks Meter: 35
does this solution requires testpoint?
Old 01-02-2023, 22:44   #4 (permalink)
Member: 2500215
Thanks Meter: 378
Reset is more important than FRP for many models
The Following User Says Thank You to Southsider2009 For This Useful Post:
Old 01-02-2023, 23:18   #5 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 125
It was missing to include the 710 processor, like the oppo rx 17 pro.
Old 01-03-2023, 05:51   #6 (permalink)
Iftakhar Rajper's Avatar
Member: 2705849
Thanks Meter: 643
Required tp for remove frp....?
The Following User Says Thank You to Iftakhar Rajper For This Useful Post:
Old 01-03-2023, 06:32   #7 (permalink)
Member: 2690714
Thanks Meter: 55
oppo no need testpoint edl.
recovery => connect cable => tab to version 1.2 10 time, click ok
all new oppo allow factory from recovery
The Following User Says Thank You to hoangtrongfb For This Useful Post:
Old 01-03-2023, 07:24   #8 (permalink)
Member: 1185918
Sonork: 100.1617322
Thanks Meter: 315
We are waiting for the Samsung latest binary patch.
The Following 5 Users Say Thank You to qasir_amz For This Useful Post:
Old 01-03-2023, 09:52   #9 (permalink)
WALIYNE's Avatar
Member: 2476740
Thanks Meter: 339
Honestly you need to Work on your Samsung New Android Version repair and Patch.With Oppo update I think it's better to add factory reset on it, without that we don't really need Frp remove.
The Following User Says Thank You to WALIYNE For This Useful Post:
Old 01-03-2023, 10:48   #10 (permalink)
Member: 2973928
Thanks Meter: 192
Good Job But We Need Samsung Repair & Patch For New Security
Old 01-03-2023, 11:27   #11 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,959
Oppo A5 2020
Oppo A3S add
Old 01-03-2023, 11:34   #12 (permalink)
equinoks's Avatar
Member: 21508
Thanks Meter: 166
Good move.. waiting for full factory reset !
The Following User Says Thank You to equinoks For This Useful Post:
Old 01-03-2023, 12:37   #13 (permalink)
Member: 1787203
reply
Dear Iftakhar,
Thank you for the question. Most of the OPPO devices will not require TestPoint because with a button combination the phone will boot up in EDL mode.
Best regards
Sab
Chimera team
The Following User Says Thank You to Chimera Tool For This Useful Post:
Old 01-03-2023, 12:38   #14 (permalink)
Member: 1787203
reply
Dear User,
Certainly, will we have an update for that as well. However, we are focusing on other modules/brands too!
Best regards
Sab
Chimera team
Old 01-03-2023, 14:12   #15 (permalink)
allumts's Avatar
Member: 1564612
Thanks Meter: 12,282
Hello,
sorry, but why not FACTORY RESET with Pin/pattern lock only FRP and 15 min.s?
I've done A53s CPH2135/37 "Factory reset" with Pin forgot and FRP removed, in 1 min. just used "[prog_firehose_ddr_fwupdate.elf]" No Test Point, no need for OPPO, you know.
If want i post LOG, (w/o show Tool).
Saddly launch serious Update, you tool not cost 20$ but more of 100$.
I understand is Multibrand, but only one Oppo FRP how Update for me is very poor update.
Allumts
The Following 3 Users Say Thank You to allumts For This Useful Post:
Page generated in 0.19181 seconds with 7 queries
