08-03-2020, 09:20 | #1 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Romania, Fagaras Age: 46
Member: 34379 Status: Offline Thanks Meter: 101 | P30 Pro cant`t flash Printing phone history Repair Recovery 8/3/2020 8:15:11 AM Usb Firmware Update 8/3/2020 8:13:40 AM Repair Recovery 8/3/2020 8:10:52 AM Load Factory Fastboot 8/3/2020 8:09:19 AM Exit Factory Mode 8/3/2020 8:07:06 AM Repair recovery Checking if factory challenge needed... Already unlocked. Extracting firmware Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PREAS. Processing PREAVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing UFSFW. Pre-processing image files Flashing image files Flashing ptable Flashing xloader Fastboot flashPartiton command error. Finished at local time: [08.03.20 11:16:50] WorkID: 102666786 |
08-03-2020, 10:06 | #2 (permalink) | |
Freak Poster Join Date: Jul 2016 Location: Algeria
Member: 2594157 Status: Offline Sonork: 100.1679874 Thanks Meter: 121 | Quote:
08-03-2020, 13:58 | #3 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | Device Model: VOG-L29 Current software version: VOG-L29 10.0.0.195(C431E19R2P5) FB ID: 867380046955975 Hardware version: Ver2.3 Boot info: unlocked Image check: secure image verify fail Android version: 10 Battery state: 0 Key version: huawei_key_v1 Root info: RISK Rescue version: rescue0.6 Phone info: (bootloader) main version do not exist in oeminfo! VendorCountry: hw/eea Base version: VOG-LGRP2-OVS 10.0.0.195 Cust version: VOG-L29-CUST 10.0.0.19(C431) Preload version: VOG-L29-PRELOAD 10.0.0.5(C431R2) Finished at local time: [08.03.20 15:57:13] WorkID: 102688211 |
08-03-2020, 14:24 | #4 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | i just downloaded all tree files from info. Gathering phone information Processing phone information Current firmware version: 10.0.0.195 (C431E19R2P5) (hw/eea) @ VOG-L29 Firmware selection Opening the file Unpacking the archive... Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PREAS. Processing PREAVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing UFSFW. Failed to validate PACKAGE_TYPE, only OFFLINE_UPDATE typed packages are supported. Finished at local time: [08.03.20 16:22:07] |
08-03-2020, 16:05 | #5 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, Can you tell us exactly , which firmware's you tried to use ? This issue could come from a Firmware version compatible problem. We just want to check it if that theory is valid or not. Best Regards Sab Quote:
08-03-2020, 18:40 | #6 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | I use this files: VOG-LGRP2-OVS 10.0.0.195 VOG-L29-CUST 10.0.0.19(C431) VOG-L29-PRELOAD 10.0.0.5(C431R2) Phone start with huawei logo and restart loop. Connected with test point write boot, exit from factory mode. After that Phone have black screen, it is detected în fastboot and can be read info from it. Flash process give error... Last edited by valiu; 08-03-2020 at 18:46. |
08-05-2020, 09:12 | #7 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, Please use another firmware version with the repair recovery. It seams like this one that you used is not compatible with the device. Sab Quote:
08-10-2020, 14:50 | #9 (permalink) |
Member: 34379 Status: Offline Thanks Meter: 101 | Same error in usb update mode Unpacking the archive... Processing BASE_VERLIST. Processing BASE_VER. Processing PACKAGE_TYPE. Processing HISIUFS_GPT. Processing XLOADER. Processing FASTBOOT. Processing DTS. Processing DTO. Processing VECTOR. Processing FW_LPM3. Processing HHEE. Processing VBMETA. Processing TEEOS. Processing TRUSTFIRMWARE. Processing SENSORHUB. Processing FW_HIFI. Processing KERNEL. Processing MODEMNVM_UPDATE. Processing MODEMNVM_CUST. Processing MODEM_DRIVER. Processing RECOVERY_RAMDISK. Processing RECOVERY_VENDOR. Processing RECOVERY_VBMETA. Processing PREAS. Processing PREAVS. Processing ERECOVERY_KERNEL. Processing ERECOVERY_RAMDISK. Processing ERECOVERY_VENDOR. Processing ERECOVERY_VBMETA. Processing ENG_VENDOR. Processing ENG_SYSTEM. Processing HDCP. Processing CACHE. Processing RAMDISK. Processing SUPER. Processing VBMETA_SYSTEM. Processing VBMETA_VENDOR. Processing VBMETA_ODM. Processing VBMETA_HW_PRODUCT. Processing VBMETA_CUST. Processing ISP_FIRMWARE. Processing MODEM_FW. Processing HISEE_IMG. Processing PATCH. Processing UFSFW. Failed to validate PACKAGE_TYPE, only OFFLINE_UPDATE typed packages are supported. Finished at local time: [08.10.20 16:48:40] WorkID: 103435504 |
08-10-2020, 16:42 | #10 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,744 | reply Dear User, You have to use the OFFLINE Update, only in that case can you do the firmware flashing. Sab Quote:
