Register | FAQ | Donate | Forum Rules | Root any Device | ★iPhone Unlock★ | ★ Wholesale Unlock ★ | Direct Unlock Source | Search | Today's Posts | Mark Forums Read |
![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Apr 2017
Member: 2704006 Status: Offline Thanks Meter: 162 | Please fix patch cert for S20 and Note 20 Series Please fix patch cert for S20 and Note 20 Series, because after Factory Reset patch cert not working. All steps are success in latest security. Remove Demo, Repair imei and Patch cert. Code: Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G780F Carrier ID: WWD Sales Code: TUR Country Code: T-RK-YE Timezone: Asia/Dushanbe Android Version: 13 [TP1A.220624.014] [SDK 33] Build Date: Fri Nov 18 13:32:32 +07 2022 PDA Version: G780FXXUAEVK5 [november 2022, rev5] Phone Version: G780FXXUAEVK3 [november 2022, rev3] CSC Version: G780FOJMAEVK3 [november 2022, rev3] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Imei: --------------------------- Battery Status: 4.01V (80%) Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2022-11-01 Em Did: 200AF6AC6B632011 Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! About 5-20 seconds after the phone has started, check the imei status. You can check the status of imei by using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [03.03.23 10:31:09] WorkID: 214087033 |
![]() | #3 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012
Member: 1787203 Status: Offline Thanks Meter: 22,145 | reply Dear User, The Patch Cert method is not a permanent solution at the moment. Once you do a factory reset or once you flash the device, the method will be wiped from the phone. Hopefully, later on we can update the Patching so it will be permanent. Best regards Sab Chimera team Quote:
![]() | #4 (permalink) | |
Member: 2704006 Status: Offline Thanks Meter: 162 | Quote:
see here, all logs | |
![]() | #6 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 22,145 | reply Dear [email protected], Thank you for the question. Yes, that firmware version is supported. We just updated that model type, so we can handle all the firmware versions. Best regards Sab Chimera team Quote:
![]() | #7 (permalink) | |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2006 Location: Palermo
Member: 281998 Status: Offline Thanks Meter: 107 | Quote:
The symbol of the net prohibition always remains. Please Help me | |
