Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 01-07-2016, 11:33   #1 (permalink)
Member: 908175
Thanks Meter: 314
plz team help cant reset eelock or email
i have samsung g928f edge plus for reset email but it wont let me do plz help how to remove that email acount thanks
Reset FRP Lock
06/01/2016
18:21:00
SW Change
06/01/2016
18:21:00
Reset EE Lock
06/01/2016
18:21:00
Reset EE Lock
06/01/2016
18:21:00
Reset Reactivation Lock
06/01/2016
18:21:00
[Reset EE lock started]
Processing...
Waiting for download mode.
Connecting.
Initializing.
Reading PIT.
Reseting.
Unable to reset.
Finished at local time: [01.07.16 10:31:10]
WorkID: 8664926
Old 01-07-2016, 11:34   #2 (permalink)
Member: 908175
Thanks Meter: 314
i have tryed all
Reset EE Lock
06/01/2016
18:21:00
Reset FRP Lock
06/01/2016
18:21:00
SW Change
06/01/2016
18:21:00
Reset EE Lock
06/01/2016
18:21:00
Reset EE Lock
06/01/2016
18:21:00
[Reset FRP lock started]
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Restarting phone.
Unable to restart. Please restart phone manually!
Please install a stock firmware.
Finished successfully.
Finished at local time: [01.07.16 10:34:10]
WorkID: 8664965
Old 01-07-2016, 12:10   #3 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 23,706
reply
Dear Sir,
first of all thank you for your report.
You are the first user who reported the mentioned problem, that is why at the moment we have not idea what happened.
Our developer team investigate the problem, I hope shortly we will have solution for the problem.
Best regards
Nicole
Originally Posted by qasi786 View Post
i have tryed all
Reset EE Lock
06/01/2016
18:21:00
Reset FRP Lock
06/01/2016
18:21:00
SW Change
06/01/2016
18:21:00
Reset EE Lock
06/01/2016
18:21:00
Reset EE Lock
06/01/2016
18:21:00
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Restarting phone.
WorkID: 8664965
Old 02-09-2016, 02:30   #4 (permalink)
Member: 1532892
Sonork: 1603006
Thanks Meter: 44
Chimera Versión de la Mobile Phone Utility: 9.21.1738 @ 2016-02-08
Printing phone history
SW Change
09/02/2016
1:23:09
SW Change
09/02/2016
1:20:03
Reset FRP Lock
08/02/2016
23:56:50
SW Change
07/09/2015
21:08:50
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Restarting phone.
Finished at local time: [02.08.16 19:28:01]
WorkID: 9192249
Old 02-09-2016, 10:01   #5 (permalink)
Member: 1787203
reply
Dear Sir, I only see that this process were successful. Is there any problems? If yes please explain it for me. Best Regards Chimera Team
SW Change
09/02/2016
1:23:09
SW Change
09/02/2016
1:20:03
Reset FRP Lock
08/02/2016
23:56:50
SW Change
07/09/2015
21:08:50
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Restarting phone.
WorkID: 9192249
Old 09-06-2016, 13:56   #6 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
s6 g920f problem
[Reset reactivation lock started]
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Unable to reset.
Finished at local time: [۰۹.۰۶.۱۶ ۱۷:۵۲:۵۹]
WorkID: 13277758
Old 09-06-2016, 14:25   #7 (permalink)
Member: 1787203
reply
Dear Sir,
if it is possible, try to downgrade your firmware, if it is done, try again the Reset reactivation lock process.
Best regards
Nicole
Originally Posted by yasermalik View Post
s6 g920f problem
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Unable to reset.
WorkID: 13277758
Old 09-06-2016, 16:08   #8 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
tried few firmaware but it gives error
Old 09-06-2016, 16:10   #9 (permalink)
Member: 1787203
reply
Dear Sir,
could you write me some more information about the mentioned error?
Old 09-06-2016, 16:16   #10 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
<ID:0/010> Added!!
<OSM> Enter CS for MD5..
<OSM> Check MD5.. Do not unplug the cable..
<OSM> Please wait..
<OSM> G920FXXU3DPBQ_G920FVFG3DPBQ_G920FXXU3DPBQ_HOME.tar .md5 is valid.
<OSM> Checking MD5 finished Sucessfully..
<OSM> Leave CS..
<ID:0/010> Odin engine v(ID:3.1005)..
<ID:0/010> File analysis..
<ID:0/010> SetupConnection..
<ID:0/010> Initialzation..
<ID:0/010> Get PIT for mapping..
<ID:0/010> Firmware update start..
<ID:0/010> SingleDownload.
<ID:0/010> sboot.bin
<ID:0/010> NAND Write Start!!
<ID:0/010> FAIL!
<ID:0/010>
<ID:0/010> Complete(Write) operation failed.
<OSM> All threads completed. (succeed 0 / failed 1)
Old 09-06-2016, 16:33   #11 (permalink)
yasermalik's Avatar
Member: 488632
Thanks Meter: 391
[Firmware update started.]
Processing firmware...
Flashing firmware...
Connecting.
Reading PIT.
Flashing sboot.bin
The firmware downgrade may not be allowed.
Flash firmware failed.
Finished at local time: [۰۹.۰۶.۱۶ ۲۰:۳۲:۲۹]
WorkID: 13283000
Old 09-06-2016, 19:17   #12 (permalink)
gcceleghg's Avatar
Member: 1766567
Thanks Meter: 1,788
Connecting.
Reading PIT.
Flashing sboot.bin
WorkID: 13283000
Flash ENG Sboot, then reset FRP, after then flash regular Sboot to get to main menu.
1. Put phone into download mode.
2. Open odin and select BL tab and flash Eng_Sboot
3. Put phone back into download and wipe FRP
4. Put phone back into download.
5. Select BL tab in Odin and flash Stock_Sboot
FRP REMOVED!!!
Old 09-12-2016, 10:56   #13 (permalink)
Member: 2477800
Thanks Meter: 5
FRP REMOVED!!!
do you you have a link for the file please?
Old 10-17-2016, 21:56   #14 (permalink)
Member: 1129807
there is a possibility to remove a frp (g925f,g928f) with a new security 6.0.1 ?
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Unable to reset.
Finished at local time: [10.17.16 23:49:37]
it is not possible downgrade at 5.1.1
thank you
Old 10-18-2016, 11:07   #15 (permalink)
Member: 1787203
reply
Dear Sir,
If the phone has new 6.0.1 version frp lock remove process will be unsuccessful.
Naturally if you can send us work id I can check the exact situation in your case.
Best regards
Nicole
Processing...
Connecting.
Initializing.
Reading PIT.
Reseting.
Unable to reset.
thank you
Page generated in 0.24334 seconds with 8 queries
