09-15-2018, 10:18 | #1 (permalink) |
No Life Poster Join Date: Oct 2006
Member: 362622 Status: Offline Thanks Meter: 43 | s7 edge 8. unlocked but now dead ??? - SOLVED i unlocked this s7 edge by chimera i obtain codes by flashing appropriate moden proposed by boxe i enter code it was ok and i had to flash original firmware to recuperate the orignal modem then downloaded the firmware automticly by chimera flashed but error while flashing stopped and now the phone don t boot just can go in download mode please any hep urgently Extracting firmware... Unzipping firmware: BL_G935FXXU2ERH1_CL13895453_QB19170474_REV00_user_ low_ship.tar.md5. Unzipping firmware: AP_G935FXXU2ERH1_CL13895453_QB19170474_REV00_user_ low_ship_meta.tar.md5. Unzipping firmware: CP_G935FXXU2ERH1_CP10287333_CL13895453_QB19170474_ REV00_user_low_ship.tar.md5. Unzipping firmware: HOME_CSC_TEF_G935FTEF2ERH1_CL14103271_QB19180088_R EV00_user_low_ship.tar.md5. Unzipping firmware: CSC_TEF_G935FTEF2ERH1_CL14103271_QB19180088_REV00_ user_low_ship.tar.md5. Processing firmware... Flashing firmware... Waiting for download mode. Connecting. SBL Info: Modèle: SM-G935F, Region: EUR, Provider: OPEN, PDA: G935FXXU2ERE8 Valid PIT file can be found in the firmware: HERO2LTE_EUR_OPEN_HIDDEN300M.pit Use the "Enable PIT Write" option if you want to use it. Reading PIT from phone. Flashing boot.img Flashing recovery.img Flashing system.img Firmware Flash échoué. Finished at local time: [09.15.18 11:16:45] WorkID: 44148315 itested also another firmware 8.0 by odin and same problem <ID:0/047> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> Checking MD5 finished Sucessfully.. <OSM> Leave CS.. <ID:0/047> Odin engine v(ID:3.1301).. <ID:0/047> File analysis.. <ID:0/047> Total Binary size: 4113 M <ID:0/047> SetupConnection.. <ID:0/047> Initialzation.. <ID:0/047> Set PIT file.. <ID:0/047> DO NOT TURN OFF TARGET!! <ID:0/047> Get PIT for mapping.. <ID:0/047> Firmware update start.. <ID:0/047> NAND Write Start!! <ID:0/047> SingleDownload. <ID:0/047> sboot.bin <ID:0/047> param.bin <ID:0/047> cm.bin <ID:0/047> boot.img <ID:0/047> recovery.img <ID:0/047> system.img <ID:0/047> <ID:0/047> Complete(Write) operation failed. <OSM> All threads completed. (succeed 0 / failed 1) |
09-15-2018, 19:36 | #3 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,336 | Hi, please just reflash device with combination firmware for your binary version, then wipe device and use 4 files firmware in order to get your device 1000% working... Best Regards Shensohau |
