03-27-2023, 16:08 | #1 (permalink) |
Junior Member Join Date: Oct 2021 Location: Rus
Member: 2998023 Status: Offline Thanks Meter: 2 | Realme 8 5G Rmx3241 Imei not found But in chimera error “Imei not found. “ Printing phone history IMEI Repair 27.03.2023 10:31 Restore / Store backup 27.03.2023 10:09 Update Firmware 27.03.2023 9:46 Root 27.03.2023 9:37 IMEI Repair 27.03.2023 9:36 Repair IMEI Reading data from the phone... Filesystem error IMEI not found Finished at local time: [03.27.23 19:19:45] WorkID: 216385339 Chimera Mobile Phone Utility version: 35.21.1519 @ 2023-03-27 Printing phone history Get Info 27.03.2023 13:24 Get Info 27.03.2023 13:16 Root 26.03.2023 17:37 Get Info 26.03.2023 17:36 Autodetect features Change to bootrom mode ADB interface detected. Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! bootrom interface detected. Initializing... Autodetect features Reading data from the phone... Reading data from the phone... IMEI not found None of the currently available methods worked Supported procedures: Store/Restore Backup Bootloader Update Firmware Remove FRP lock Root Finished at local time: [03.27.23 19:30:10] WorkID: 216386303 |
03-27-2023, 17:54 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,746 | reply Dear *****, Can you please reflash the device and then do the IMEI REPAIR method? If you can , please post the result of it. Best regards Sab Chimera team Quote:
03-27-2023, 19:12 | #3 (permalink) |
Member: 2998023 Status: Offline Thanks Meter: 2 | I flash to another firmware but still have this error Chimera Mobile Phone Utility version: 35.25.1604 @ 2023-03-28 Printing phone history SW Change 26.03.2023 18:36 Repair IMEI Change to bootrom mode ADB interface detected. Please put the phone manually to bootrom mode! You might need to hold some combination of the volume up/down keys while plugging in the USB cable to a powered off phone, or via test point! bootrom interface detected. Initializing... Reading data from the phone... Reading data from the phone... IMEI not found Finished at local time: [03.28.23 00:08:14] WorkID: 216415468 |
