01-26-2023, 10:51 | #1 (permalink) |
No Life Poster Join Date: Oct 2005 Location: AsTeknik Elektronik
Member: 194874 Status: Offline Thanks Meter: 458 | Huawei MAR-LX1A (P30 Lite) FRP & HUAWEI ID REMOVE Chimera Mobile Phone Utility version: 33.01.1235 @ 2022-08-16 Printing phone history Enter Factory Mode 16.08.2022 08:47 Removing Huawei account Rebooting phone to factory mode Changing to factory mode Rebooting phone to USB update mode Downloading ERECOVERY files Flashing ERECOVERY files Failed to flash the eRecovery file, falling back to manual reboot. Please put the phone into factory mode via Test Point! Or do an USB firmware update with a firmware version that is equal or not much older than the one currently on the phone. If you used Test Point to switch into factory mode, you should immediately reconnect your phone's battery as soon as the program detects the device. If you fail to reconnect the battery, your phone might be still locked after the procedure finished Uploading data... Servicing the phone Please be patient, this step can be long. DO NOT DISCONNECT the phone while the procedure is running. It can damage your phone permanently. The phone will automatically start factory reset, after that it might shut down. You need to turn on the phone afterwards. IMPORTANT! Please do not connect your phone to the Internet (WiFi) and ensure there's no SIM-card present in the phone until you have completed the initial setup wizard! Finished at local time: [08.16.22 11:58:27] WorkID: 191650859 |
01-26-2023, 10:53 | #2 (permalink) |
Member: 194874 Status: Offline Thanks Meter: 458 | Xiaomi Poco M4 Pro 5G (21091116AG)(Evergreen) IMEI REPAIR 1 - Unlock Bootloader (Manual) 2 - Patch Imei Dual Sim (Chimera) Chimera Mobile Phone Utility version: 33.74.1311 @ 2022-10-29 Printing phone history Restore / Store backup 20.10.2022 10:54 Patch IMEI Creating backup... Saving to file: C:/Program Files (x86)/Chimera/Backup/Xiaomi/Unknown MTK Xiaomi (evergreen)/Unknown MTK Xiaomi (evergreen)-patch-imei-2022-10-29-165919.zip Reading... Reading: nvdata Reading: vbmeta_a Reading: vbmeta_b Reading: boot_a Reading: proinfo Reading: nvram Reading: boot_b Reading data from the phone... Original IMEI1: 86xx Original IMEI2: 86xx Patching boot partition Writing new IMEI(s) Waiting for the phone to restart... Please reboot your phone by long-pressing the power button! Be aware that the effect of this procedure lasts only until the system is unchanged. Doing a firmware update or an OTA update likely causes the phone to restore to its original state. Finished at local time: [10.29.22 17:01:11] WorkID: 200991106 |
01-26-2023, 11:00 | #3 (permalink) |
Member: 194874 Status: Offline Thanks Meter: 458 | HTC 0PJA100 (One M9) IMEI REPAIR Chimera Mobile Phone Utility version: 30.64.1318 @ 2021-12-30 Printing phone history Get Info 30.12.2021 13:42 Repair IMEI 30.12.2021 13:27 IMEI repair started Rebooting in Fastboot mode Phone detected Current security state: 3 Checking current security flag Downloading recovery image from server. Please hold on, it can take a while. Recovery image has been downloaded. Switching to Fastboot mode Phone detected Checking Bootloader state... Phone detected Using new method Rebooting in Bootloader mode Phone detected Bootloader is unlocked Rebooting in download mode Phone detected Bootloader is already unlocked Installing recovery image Installing was successful ? 1.) Please select Reboot to Bootloader option from Download mode menu 2.) Select Boot to Recovery mode option from the Bootloader menu ? Waiting for ADB device Initializing recovery mode Recovery mode detected, preparing phone, do not touch the phone. Waiting for the phone... Gathering phone information Communicating with Chimera server Preparing the phone for the procedure Calculating encrypted data Rebooting in recovery mode Cleaning up Checking Current security flag: 0 Information Your phone may asks for decryption password after it boots.?Please type a single zero digit, then press the enter button. After that the phone will ask you for Factory Reset. Push Reset button, then phone boots into TWRP recovery. It may ask also for decryption password, but cancel it. It's IMPORTANT to push the Keep Read Only button (if it exists) on TWRP landing screen. Please go to the Wipe Menu in the TWRP recovery and pull the sliding bar to reset.?After that you can boot into system mode and use the phone as usual.??All in all: please factory reset your phone. Restarting in Fastboot mode Phone detected Writing IMEI(s) IMEI1 to write: 357xx Checking current security flag Writing security flag Phone detected Security flag has been written: S-ON Successfully finished Finished at local time: [12.30.21 17:18:43] WorkID: 164180758 |
01-26-2023, 11:02 | #4 (permalink) |
Member: 194874 Status: Offline Thanks Meter: 458 | Oppo Reno 4 Lite (CPH2125) Android 12 FRP REMOVE Chimera Mobile Phone Utility version: 34.58.1110 @ 2023-01-25 Remove FRP lock Removing factory reset protection... Waiting for the phone to restart... Please reboot your phone by long-pressing the power button! Finished at local time: [01.25.23 17:08:57] WorkID: 210518091 |
01-26-2023, 11:04 | #5 (permalink) |
Member: 194874 Status: Offline Thanks Meter: 458 | ZTE Blade L5 Plus IMEI REPAIR Chimera Mobile Phone Utility version: 32.27.1139 @ 2022-06-06 Repair IMEI Searching for manufacture port... Restarting the phone. Found preloader device: MediaTek PreLoader USB VCOM (Android) (COM22) Request sent ADB interface detected. Found factory port: MediaTek USB VCOM (Android) (COM1095) Connected to the phone Writing new IMEI(s) Initializing... Connected to the phone Writing new IMEI(s) Original IMEI1: 869xx Original IMEI2: 869xx New IMEI1: 351xx New IMEI2: 351xx Done. Restarting the phone... Finished at local time: [06.06.22 17:11:51] WorkID: 183038237 |
01-26-2023, 13:45 | #6 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,744 | Good jobs once again! Thank you for sharing those with us, however, please post these jobs HERE. Thank you for your understanding. Best regards Sab Chimera team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
