![]() | #1 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Dec 2017 Location: Dar es salaam,Tanzania
Member: 2790329 Status: Offline Thanks Meter: 27 | Repair imei and patch cert done on samsung j701f but status came ng After success to repair imei and patch cert,status wa s ok and network working but after hours status change to NG i repeat the process but still the same problem. Here are log and work id Chimera Mobile Phone Utility version: 20.24.1610 @ 2019-02-19 Printing phone history Patch Certificate2/19/20197:19:38PMPatch Certificate2/19/20196:34:47PMRepair IMEI2/19/20196:30:33PMPatch Certificate2/19/201912:40:53PMRepair IMEI2/19/201912:37:42PM Patch certificate started Gathering phone info... Collecting information.*Be patient! Do NOT disconnect the phone! Model:*SM-J701F Sales Code:*XID Country Code:*INDONESIA Timezone:*Africa/Dar_es_Salaam Android Version:*8.1.0 [M1AJQ] [SDK 27] Build Date:*Thu Aug 23 18:47:46 KST 2018 PDA Version:*J701FXXU6BRH9 [august 2018, rev9] Phone Version:*J701FXXU6ARH1 [august 2018, rev1] CSC Version:*J701FOLE6BRH9 [august 2018, rev9] Product Code:*XID HIDSw Version:*J701FXXU6BRH9/J701FOLE6BRH9/J701FXXU6ARH1/J701FXXU6BRH9 Board Platform:*EXYNOS5 Modem Platform:*SHANNON315 Serial Number:*RZ8K62WFN0A Imei:*356629062110834 Unique Number:*CAJ003875EC9F25 Connections:*AT,MTP Battery Status:*3.74V (11%) Network Type:*GSM SIM Status:*READY,READY Multisim Config:*DSDS Knox Version:*v30 Warranty Bit:*1 Security Patch:*2018-06-01 Data Encryption State:*encrypted Preparing... Checking current patchcert. Checking modem. Checking root. Checking boot image.*Be patient! Do NOT disconnect the phone! Reading data... Checking modem version. Reading data.*Be patient! Do NOT disconnect the phone! Patching certificate... Communicating with the server.*Be patient! Do NOT disconnect the phone! After the process, the phone can restart once during startup. Within 20-70 seconds after the phone starts, the signal strength indicator will toggle: signal -> no signal -> signal. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.19.19 22:59:05] WorkID: 52992547 ![]() ![]() Sent from my CAM-L21 using Tapatalk |
The Following User Says Thank You to son_of_masia For This Useful Post: |
![]() | #2 (permalink) | |
Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 25,852 | reply The most common errors that might suggest such a problem with the phone are the following:
Without going into technical details, the process includes the following steps: At the end of the process a Patch CERT is needed in order to switch the checking phase off! Repair IMEI:
