Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 11-06-2019, 16:04   #331 (permalink)
Member: 1391134
Thanks Meter: 47
please add j410f and j415f imei repair and patch cert
Old 11-11-2019, 11:32   #332 (permalink)
Member: 2575029
Thanks Meter: 122
hi chimera team
pls add wipe efs with sideload and edl mode xiaomi
repiar imei xiaomi new phone
mi8.mi9.note7.mi 9t and....
Old 11-11-2019, 11:33   #333 (permalink)
Member: 2575029
Thanks Meter: 122
add repiar and patch j260.j400 and...
thx for hard work
Old 11-11-2019, 14:16   #334 (permalink)
Member: 2935044
Thanks Meter: 75
- sm-g9300
- sm-g9308
- sm-g930a
- sm-g930az
- sm-g9350
- sm-g935a
Old 11-12-2019, 07:35   #335 (permalink)
Member: 2136677
Thanks Meter: 6
j250f imei repair ptch cert?
Old 11-12-2019, 08:45   #336 (permalink)
Registered User
Member: 1545797
Sonork: 1596859
Thanks Meter: 91
plz add samsung G960W for imei repair
Old 11-13-2019, 12:51   #337 (permalink)
Member: 2576731
Thanks Meter: 103
Chimera Mobile Phone Utility version: 22.94.1309 @ 2019-11-13
Printing phone history
HUAWEI P SMART FIG-LA1
FRP FAILL
Removing factory reset protection...
Collecting information about the device...
Removing factory reset protection lock...
It did not work.
It did not work.
Checking if factory challenge needed...
Reading factory challenge...
Calculating response for the challenge...
This may take a while.
Be patient! Do NOT disconnect the phone!
Sending response to the device...
It did not work.
It did not work.
It did not work.
It did not work.
Failed to send the response!
Finished at local time: [11.13.19 13:44:35]
WorkID: 79226093
PLS FIX THIS ERROR PLS MOST OF HUAWEI IS NOT SUPPORTED
Old 11-15-2019, 16:49   #338 (permalink)
Member: 2568942
Sonork: no id
Thanks Meter: 9
Oppp all model frp pattern flash
Old 11-20-2019, 14:55   #339 (permalink)
eyobaaa's Avatar
Member: 2102546
Thanks Meter: 493
Imei repair and patch cert for J610f, j610g, we lost a lot of money please work hard on this model and be the first in the world
BR,
Baya
Old 11-20-2019, 16:41   #340 (permalink)
Member: 2136677
Thanks Meter: 6
j250f imei repair j250f imei repair
Old 12-20-2019, 17:08   #341 (permalink)
Member: 2111301
Sonork: 1651880:UzjavaAzizbek
Thanks Meter: 65
Thanks CHimera team Hard work please add Huawei ATU-L31 imei repair (Huawei qualcom imei repair) and samsung j250F imei repair patch cert(this qualcom msm425)
The Following User Says Thank You to UzjavaAzizbek For This Useful Post:
Old 01-07-2020, 17:02   #342 (permalink)
WALIYNE's Avatar
Member: 2476740
Thanks Meter: 339
Samsung a70 repair and patch cert.
Old 01-11-2020, 11:18   #343 (permalink)
Member: 2704006
Thanks Meter: 181
Thanks for Chimera support. Because they add new models. This models are first in the world.
If its possible please add Redmi 7 flash with edl mode
Old 01-11-2020, 13:08   #344 (permalink)
Member: 2705008
Sonork: 12885689
Thanks Meter: 7
Chimera Tools looked helps please
If this is your first time, please write to our support, we will review your case and if this is your first time, be not worry we will enable your account... My Account GSMFARUKSFC
Thank you to play fair...
Old 01-13-2020, 12:29   #345 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 24,797
reply
Hi,
first of all, please in a future use the correct topic for the license/account cases.
Your account is blocked by the Chimera tool Team. The reason behind the action is that you broke our policy about the License using. Our policy - which one you accepted at the registration & in the chimera tool software - says that you are not able to share the tool with any third party software / tool. We discovered that despite our policy
As this is the first time that we detected this issue with your account, we unblock it. Take it as a Warning from our system. Please do not use any third party software / driver / tool. DO NOT SHARE THE TOOL.
By the next detection your account will be blocked again and we are unable to activate it anymore.
https://chimeratool.com/en/info/term...privacy-policy
13 Suspending and blocking the User account
The registered account of the User may be suspended, and, in certain cases, blocked permanently if the User breaches or abuses the above-mentioned rules. As a result of blocking the User account, the data stored in the User’s account may not be accessed, the User may not use the product purchased, may not register a new account and all previous payment possibilities will be disabled.
In addition to the rules set out above, any detected attempts at the followings will be regarded as grave violations of rules:
  • attempts at cracking the products distributed on the Website and attempts at using them for purposes other than their intended purpose
  • attempts at sharing the products distributed on the Website, including
    • resale of licences purchased or sharing them with third parties
    • sharing USB devices with third parties
  • monitoring or reverse engineering the network or USB traffic
  • Running it under a virtual machine
  • Running it under a remote desktop
Originally Posted by FARUKGSM View Post
If this is your first time, please write to our support, we will review your case and if this is your first time, be not worry we will enable your account. My accounts GSMFARUKSFC
Page generated in 0.15407 seconds with 9 queries
