07-30-2021, 12:53 | #557 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Dear kibazoofuganda, Thank you for the request. We will try to improve the tool in that way. Also you can ask our developers for any device/service at here: LINK Best regards Sab Chimera Team |
08-12-2021, 09:18 | #563 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Dear User, Thank you for the report. Please tell us a WORK ID , from the Patch Cert job, so we can check the device itself. Best regards Sab Chimera Team |
08-12-2021, 10:15 | #565 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Dear User, You have to connect the device in ADB mode to the tool and click on the IMEI REPAIR. Basically, that is all that you have to do. But if the process fails, please let us know a work id from the problem and we can check the issue from our side. Best regards Sab Chimera team |
08-12-2021, 10:21 | #566 (permalink) |
Junior Member Join Date: Jul 2016
Member: 2596171 Status: Offline Thanks Meter: 3 | Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-M325F Carrier ID: INS Sales Code: INS Country Code: India Timezone: Asia/Tashkent Android Version: 11 [RP1A.200720.012] [SDK 30] Build Date: Mon May 24 19:16:18 KST 2021 PDA Version: M325FXXU1AUEJ [may 2021, revJ] Phone Version: M325FXXU1AUF2 [june 2021, rev2] CSC Version: M325FODM1AUEJ [may 2021, revJ] Product Code: INS HIDSw Version: M325FXXU1AUEJ/M325FODM1AUEJ/M325FXXU1AUF2/M325FXXU1AUEJ Board Platform: MT6768 Modem Platform: MT6769 Serial Number: RZ8R60N28YM Imei: 357674430427220 Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 0 Security Patch: 2021-05-01 Em Did: 20D522FF830A2C11 Repair imei... The operation is in progress. Be patient! Do NOT disconnect the phone! Repair imei failed. Finished at local time: [08.12.21 13:21:36] WorkID: 145976274 |
08-12-2021, 11:27 | #567 (permalink) | |
Junior Member Join Date: Dec 2018
Member: 2882662 Status: Offline Thanks Meter: 3 | Quote:
work id : 145894957 Patching certificate... Checking root access. The phone must be started in recovery mode to be rooted! To start recovery, you must use a key combo at startup. Usually [volume_up + power] or [volume_up + bixby + power]. Without root the patchcert will not work! Restarting phone in recovery mode... About 30-180 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. After installing new firmware, the patchcert process must be repeated. Successfully finished. Finished at local time: [08.11.21 18:21:24] WorkID: 145894957 * everything it's ok but after the patch the device automatic restart | |
08-12-2021, 11:57 | #568 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,709 | reply Dear User, You have to reflash the device with another firmware. Then boot it from recovery and perform the IMEI REPAIR and the PATCH CERT services while the Airplane mode is activated. Then reboot the device again from recovery check the device network connection. Best regards Sab Chimera Team Quote:
