01-30-2021, 21:42 | #1 (permalink) |
Freak Poster Join Date: Oct 2012
Member: 1819911 Status: Offline Thanks Meter: 5 | S10e g970u T-Mobile supported? I searched for available functions for Samsung S10e (sm-g970u) in chimeratool.com and i found that carrier relock for T-Mobile phones are supported; but in the software only appears: Network Factory Reset, RMM Remove and Knox Guard Remove. Does chimera support this phone for unlock? |
02-01-2021, 11:59 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,750 | reply Hello, Yes we do but if the device does have a high security patch, then we wont highlight the Carrier relock on the tool, because the service cannot work on them. Of course the method will be updated , but we need time. Quote:
02-08-2022, 18:53 | #3 (permalink) | |
Junior Member Join Date: Feb 2014 Location: Villa El Carmen, Managua, Nica
Member: 2131375 Status: Offline Thanks Meter: 1 | Quote:
Enviado desde mi VTR-L09 mediante Tapatalk | |
02-09-2022, 11:23 | #4 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,750 | reply Dear Wilfredoalexand, We do support the CARRIER RELOCK for the following binary versions: - Binary 2 (U2) - Binary 1 (U1) We have to note here, that some clients of ours used combination file: PDA Version: FA90_G970USQU4ATJ1 Phone Version: G970USQU4ATF1 [june 2020, rev1] However, we are not sure if it is safe to do so. It is up to you to decide. Although we can say that we do not suggest it. Best regards Sab Chimera team |
The Following 3 Users Say Thank You to Chimera Tool For This Useful Post: |
02-09-2022, 17:42 | #5 (permalink) | |
02-09-2022, 17:53 | #6 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,750 | reply No problem, if you have more questions please let us know it. You can reach us in the following ways: - Live Chat (chimeratool.com) - email: [email protected] - Skype: chimeratool - GSMHosting forum - Martview Forum Best regards Sab Chimera team |
04-13-2022, 19:32 | #7 (permalink) | |
No Life Poster Join Date: Sep 2005 Location: Havana, CUBA
Member: 181633 Status: Offline Thanks Meter: 730 | Quote:
Someone tested this solution and prove it works and it's stable? Also Chimera enabled carrier relock option for this version (G970USQU4ATF1)? Thanks for clarification. | |
04-14-2022, 08:37 | #8 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,750 | reply Dear Jepetu, The Carrier relock is enabled on the following firmware files: G970USQS2BSI4 G970USQU1ASAT G970USQU1ASBA G970USQS2ASF7 And it is added with the following Firmware combination: PDA Version: FA90_G970USQU4ATJ1 Phone Version: G970USQU4ATF1 [june 2020, rev1] Best regards Sab Chimera team |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
04-16-2022, 22:19 | #9 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | Solution Works! G970U TMB U4 Carrier Relocked!!! Just tested the solution, it works! G970U relocked, converted to U1 same bit keeping "unlocked" modem, changed CSC to remove TMobile bloatware and restrictions, finally disabled updates to avoid losing the "unlock". I think Chimera Team should enable G975U and G973U with same builds for carrier relock. Get Info Code: Get info started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G970U Carrier ID: TMB Sales Code: TMB Timezone: America/Havana Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Oct 19 11:25:05 KST 2020 PDA Version: FA90_G970USQU4ATJ1 Phone Version: G970USQU4ATF1 [june 2020, rev1] Board Platform: MSMNILE Modem Platform: SM8150 Serial Number: R58M8 Imei: 355365xxxxxxxxx Battery Status: 4.01V (71%) Network Type: GSM SIM Status: NETWORK_LOCKED Multisim Config: SS Knox Version: v00 Warranty Bit: 0 Security Patch: 2019-01-01 Em Did: 2030A590D7AAC211 Successfully finished. Finished at local time: [04.16.22 15:48:13] WorkID: 176795110 Code: Carrier relock started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G970U Carrier ID: TMB Sales Code: TMB Timezone: America/Havana Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Oct 19 11:25:05 KST 2020 PDA Version: FA90_G970USQU4ATJ1 Phone Version: G970USQU4ATF1 [june 2020, rev1] Board Platform: MSMNILE Modem Platform: SM8150 Serial Number: R58M8 Imei: 355365xxxxxxxxx Battery Status: 4.02V (71%) Network Type: GSM SIM Status: NETWORK_LOCKED Multisim Config: SS Knox Version: v00 Warranty Bit: 0 Security Patch: 2019-01-01 Em Did: 2030A590D7AAC211 Carrier relock... The operation is in progress. Be patient! Do NOT disconnect the phone! Carrier relocked. Successfully finished. Finished at local time: [04.16.22 15:49:05] WorkID: 176795175 Code: Get info started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G970U Carrier ID: TMB Sales Code: TMB Timezone: America/Havana Android Version: 9 [PPR1.180610.011] [SDK 28] Build Date: Mon Oct 19 11:25:05 KST 2020 PDA Version: FA90_G970USQU4ATJ1 Phone Version: G970USQU4ATF1 [june 2020, rev1] Board Platform: MSMNILE Modem Platform: SM8150 Serial Number: R58M8 Imei: 355365xxxxxxxxx Battery Status: 4.02V (71%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v00 Warranty Bit: 0 Security Patch: 2019-01-01 Em Did: 2030A590D7AAC211 Successfully finished. Finished at local time: [04.16.22 15:49:39] WorkID: 176795216 Code: CSC Change started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G970U1 Carrier ID: TMB Sales Code: TMB Country Code: USA Timezone: America/Havana Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Thu Jun 18 17:03:28 KST 2020 PDA Version: G970U1UEU4DTF3 [june 2020, rev3] Phone Version: G970USQU4ATF1 [june 2020, rev1] CSC Version: G970U1OYM4DTF3 [june 2020, rev3] Board Platform: MSMNILE Modem Platform: SM8150 Serial Number: R58M8 Imei: 355365xxxxxxxxx Battery Status: 4.04V (71%) Network Type: GSM SIM Status: LOADED Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-07-01 Em Did: 2030A590D7AAC211 Changing CSC... The operation is in progress. Be patient! Do NOT disconnect the phone! Successfully finished. Finished at local time: [04.16.22 16:03:48] WorkID: 176796470 |
The Following 2 Users Say Thank You to jepetu For This Useful Post: |
04-19-2022, 09:58 | #10 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,750 | reply Dear Jepetu, Thank you for the feedback! Great work! I will send your request to the team with your logs. Best regards Sab Chimera team Quote:
06-12-2022, 10:05 | #11 (permalink) | |
Insane Poster Join Date: Sep 2011 Location: @ The cyber net
Member: 1652500 Status: Offline Sonork: 100.1617312 Thanks Meter: 21 | yes it worked for U3 Quote:
thank you , it is really worked for U3 | |
06-25-2022, 20:29 | #13 (permalink) | |
Member: 181633 Status: Offline Thanks Meter: 730 | Hi Chimera Team, Have you added the following combinations of S10 firmware to CARRIER RELOCK procedure?: PDA Version: FA90_G975USQU4ATJ1 Phone Version: G975USQU4ATF1 [june 2020, rev1] PDA Version: FA90_G973USQU4ATJ1 Phone Version: G973USQU4ATF1 [june 2020, rev1] I tested it on G970U but now I have a G975U u4 for test. Thanks in advance. Quote:
06-26-2022, 04:52 | #14 (permalink) |
Member: 181633 Status: Offline Thanks Meter: 730 | This is the info from the phone I have in hands. Please activate carrier relock for that firmware combination. Thanks in advance Code: Chimera Mobile Phone Utility version: 32.47.1540 @ 2022-06-25 Get info started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G975U Carrier ID: TMB Sales Code: TMB Country Code: USA Timezone: America/Havana Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Sat Oct 10 20:01:27 KST 2020 PDA Version: G975USQS4ETJ1 [october 2020, rev1] Phone Version: G975USQU4ATF1 [june 2020, rev1] CSC Version: G975UOYN4ETJ1 [october 2020, rev1] Board Platform: MSMNILE Modem Platform: SM8150 Serial Number: R58xxxxxxxx Imei: 35xxxxxxxxxxxxxxxx Battery Status: 3.84V (52%) Network Type: GSM SIM Status: ABSENT Multisim Config: SS Knox Version: v30 Warranty Bit: 0 Security Patch: 2020-10-01 Em Did: 2030A5EF67C63911 Successfully finished. Finished at local time: [06.25.22 23:49:45] WorkID: 185496730 |
06-27-2022, 10:20 | #15 (permalink) | |
Member: 1787203 Status: Offline Thanks Meter: 23,750 | reply Dear Jepetu, Thank you, we will try to add it to this firmware and security patch combination. Best regards Sab Chimera team Quote:
