06-05-2020, 19:58 | #1 (permalink) |
Major Poster Join Date: Jul 2005 Location: egypt Age: 36
Member: 163058 Status: Offline Thanks Meter: 5 | S20 g980f patch certifacate failed Chimera Mobile Phone Utility version: 24.92.2104 @ 2020-06-05 Printing phone history Reboot 6/5/2020 6:32:52 PM Patch Certificate 6/5/2020 6:32:24 PM Patch Certificate 6/5/2020 6:31:32 PM Repair IMEI 6/5/2020 6:29:49 PM Get Info 6/5/2020 6:28:19 PM Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G980F Sales Code: WWD Country Code: Switzerland Timezone: Europe/London Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Tue Feb 18 18:27:00 KST 2020 PDA Version: G980FXXU1ATBM [february 2020, revM] Phone Version: G980FXXU1ATBM [february 2020, revM] CSC Version: G980FOXM1ATBM [february 2020, revM] Product Code: WWD HIDSw Version: G980FXXU1ATBM/G980FOXM1ATBM/G980FXXU1ATBM/G980FXXU1ATBM Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: ****XT Imei: ****940 Unique Number: ****1F7E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-03-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. Patchcert will not work. Please reinstall the firmware and try again. Unable to patch certificate. Finished at local time: [06.05.20 22:52:30] WorkID: 97149363 |
The Following User Says Thank You to sweet love For This Useful Post: |
06-06-2020, 08:27 | #3 (permalink) |
Member: 163058 Status: Offline Thanks Meter: 5 | hello bro .. i've tried but after flashing patched boot phone restarted into download showing od failed .. i've tried different firmware and same issue. i'm trying magisk in another firmware .. but sure eft is waste of time and money |
06-08-2020, 20:36 | #6 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Brasil Age: 53
Member: 22054 Status: Offline Thanks Meter: 8 | Same problem here. G980f U1 magisk root and no patch cert: Patchcert will not work. Please reinstall the firmware and try again. Teste 2 different binary 1 version and same error... |
07-23-2020, 02:03 | #12 (permalink) |
Freak Poster Join Date: Feb 2014 Location: BRazil
Member: 2123355 Status: Offline Thanks Meter: 16 | another device same inssue Chimera Mobile Phone Utility version: 25.46.0928 @ 2020-07-22 Printing phone history Repair IMEI 23/07/2020 00:58:43 Reboot 23/07/2020 00:55:05 Patch certificate started Unable to detect IMEI number. Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Sales Code: WWD Country Code: Switzerland Timezone: America/Sao_Paulo Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Jan 31 15:28:59 KST 2020 PDA Version: G985FXXU1ATB3 [february 2020, rev3] Phone Version: G985FXXU1ATB2 [february 2020, rev2] CSC Version: G985FOXM1ATB3 [february 2020, rev3] Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: R58N21235EN Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-02-01 Preparing... Checking root access. The phone is rooted by: 20.4:MAGISKSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. Patchcert will not work. Please reinstall the firmware and try again. Unable to patch certificate. Finished at local time: [07.22.20 22:01:57] WorkID: 101601043 |
07-23-2020, 22:23 | #14 (permalink) |
Member: 2123355 Status: Offline Thanks Meter: 16 | Done by eft su Chimera Mobile Phone Utility version: 25.48.1328 @ 2020-07-23 Printing phone history Patch Certificate 23/07/2020 20:46:34 Patch Certificate 23/07/2020 01:01:36 Repair IMEI 23/07/2020 00:58:43 Reboot 23/07/2020 00:55:05 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G985F Sales Code: WWD Country Code: Switzerland Timezone: America/Sao_Paulo Android Version: 10 [QP1A.190711.020] [SDK 29] Build Date: Fri Jan 31 15:28:59 KST 2020 PDA Version: G985FXXU1ATB3 [february 2020, rev3] Phone Version: G985FXXU1ATB2 [february 2020, rev2] CSC Version: G985FOXM1ATB3 [february 2020, rev3] Product Code: WWD HIDSw Version: G985FXXU1ATB3/G985FOXM1ATB3/G985FXXU1ATB2/G985FXXU1ATB3 Board Platform: UNIVERSAL990 Modem Platform: SHANNON5123 Serial Number: Imei: Unique Number: CE11193BC921BD371F7E Connections: AT,MTP Network Type: GSM SIM Status: ABSENT,ABSENT Multisim Config: DSDS Knox Version: v30 Warranty Bit: 1 Security Patch: 2020-02-01 Preparing... Checking root access. The phone is rooted by: 3.19:EFTSU Reading data... The operation is in progress. Be patient! Do NOT disconnect the phone! Patching certificate... Checking root access. About 30-90 seconds after the phone starts, the signal strength indicator turns OFF and then turns ON again after a few seconds. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Successfully finished. Finished at local time: [07.23.20 18:21:36] WorkID: 101703814 |
The Following User Says Thank You to gnvieira For This Useful Post: |
