Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Chimera Tool
Old 11-06-2024, 18:56   #1 (permalink)
Member: 2323265
Thanks Meter: 42
s21 plus remove demo & repair imei & patch success but sim 2 is not detected
Chimera Mobile Phone Utility version: 41.06.1311 @ 2024-11-05
Printing phone history
Patch Certificate11/4/202410:56PM
Remove Demo11/4/202410:52PM
Repair IMEI11/4/202410:46PM
Patch certificate started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-G996B
Carrier ID: WWA
Sales Code: ANC
Country Code: Uruguay
Timezone: Africa/Algiers
Android Version: 13 [TP1A.220624.014] [SDK 33]
Build Date: Fri Jun 23 07:45:44 KST 2023
PDA Version: G996BXXU9EWF2 [june 2023, rev2]
Phone Version: G996BXXU9EWF2 [june 2023, rev2]
CSC Version: G996BOWE9EWF2 [june 2023, rev2]
Board Platform: UNIVERSAL2100_R
Modem Platform: SHANNON5123AP
Serial Number: RFCNB0CK72B
Imei: 356xxxxxxxxxxxxxxxxx
Network Type: GSM
SIM Status: ABSENT,NOT_READY
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2023-06-01
Em Did: 2008F40F3896A011
Preparing...
Servicing phone. Be patient! Do NOT disconnect the phone!
Patching certificate...
About 20-60 seconds after the phone has started, check the imei status.
You can check the status of imei by using: *#0011#
The patchcert can be removed by repeating the process.
If  you modify firmware, imei, csc, simlock status, or if *#0011# does not  show "IMEI Status: OK", you should repeat the patchcert process.
Successfully finished.
Finished at local time: [11.05.24 00:04:16]
WorkID: 320229250
i managed to get lte and 3g working using phone info.apk
but sim 2 not working even in settings the phone behaving like 1 sim model
Old 11-07-2024, 12:49   #2 (permalink)
Chimera Tool's Avatar
Member: 1787203
Thanks Meter: 25,299
Dear User,
Are you sure that this issue is not caused by the APK? We would suggest you doing the IMEI Repair and Patch Cert with a different firmware and root combination.
Regards,
ChimeraTeam
Model: SM-G996B
Carrier ID: WWA
Sales Code: ANC
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
WorkID: 320229250
Old 11-12-2024, 13:13   #3 (permalink)
Member: 2323265
Thanks Meter: 42
lol the apk is just a shortcut to *#*#4636#*#*
you do not need to deflect i wasn't blaming anyone
any firmware recommended
Old 11-12-2024, 13:40   #4 (permalink)
Member: 1787203
Dear User,
You can try G996BXXS9EWF3 + MAGISK 28.0
Regards,
ChimeraTeam
The Following User Says Thank You to Chimera Tool For This Useful Post:
Page generated in 0.13804 seconds with 8 queries
