04-17-2020, 09:46 | #1 (permalink) |
No Life Poster Join Date: Feb 2006 Location: on a different planet
Member: 228253 Status: Offline Thanks Meter: 22 | S6 edge no imei Thanks |
04-17-2020, 12:46 | #3 (permalink) | |
No Life Poster Join Date: Jun 2012 Location: Arg
Member: 1766567 Status: Offline Thanks Meter: 1,788 | Quote:
Dear Sir! If you say that Chimera Tool cannot read the information on the phone, then you will not be able to do any operations and apart from not having a baseband, it does not have an IMei and security is damaged, you should also check the charging pin to know if you have a physical problem on your phone. | |
04-17-2020, 13:29 | #4 (permalink) |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Hi, could you send me the work id of the chimera process what you started on the device? Thank you in advance! Best regards Nicole |
The Following User Says Thank You to Chimera Tool For This Useful Post: |
04-19-2020, 00:19 | #5 (permalink) | |
Member: 228253 Status: Offline Thanks Meter: 22 | Quote:
05-04-2020, 18:31 | #9 (permalink) |
No Life Poster Join Date: Aug 2010 Location: Inside Logic Age: 37
Member: 1377783 Status: Offline Sonork: 100.1611724 Thanks Meter: 3,335 | Hi, flash combination firmaware, perform full wipes, then check imei condition if going generic or 3500000 just reflash full 4 parts stock and then repair with chimera |
The Following 2 Users Say Thank You to Shensohau For This Useful Post: |
05-07-2020, 00:32 | #10 (permalink) | |
Can someone please help | |
05-07-2020, 12:45 | #11 (permalink) |
Member: 1787203 Status: Offline Thanks Meter: 23,734 | reply Hi, when I see the problem comes from the modem side, in each case I see the follow error message in a logs: "Unable to detect IMEI number and baseband version. It seems that the modem does not work or the network is unavailable/disabled." In a 99% of the cases the problem can be solved with an stock firmware. When you already installed stock firmware on the device and the problem still not solved, check the modem from hardware side. Best regards Nicole |
05-08-2020, 01:32 | #12 (permalink) | |
05-09-2020, 13:36 | #14 (permalink) |
No Life Poster Join Date: Aug 2011 Location: UK
Member: 1629133 Status: Offline Thanks Meter: 498 | Try full flash with ODIN you need to check what version you have we i check befroe unlock and save ... Another solution for fix imei is for write new certificate but you need to see if you have baseband... |
