02-11-2020, 12:10 | #1 (permalink) |
No Life Poster Join Date: Nov 2010 Location: RSA-2048 Age: 38
Member: 1444462 Status: Offline Thanks Meter: 1,337 | SM-G532F patchcert Successfully finished but still Emergency calls only Chimera Mobile Phone Utility version: 23.78.1329 @ 2020-02-11 Patch certificate started Gathering phone info... Collecting information. Be patient! Do NOT disconnect the phone! Model: SM-G532F Sales Code: XFA Country Code: SOUTH AFRICA Timezone: Africa/Johannesburg Android Version: 6.0.1 [MMB29T] [SDK 23] Build Date: Mon Feb 11 15:57:19 KST 2019 PDA Version: G532FXWU1ASB1 [february 2019, rev1] Phone Version: G532FXXU1ARF3 [june 2018, rev3] CSC Version: G532FOJV1ASB1 [february 2019, rev1] Product Code: SM-G532FTKAXFA HIDSw Version: G532FXWU1ASB1/G532FOJV1ASB1/G532FXXU1ARF3/G532FXWU1ASB1 Board Platform: MT6737T Modem Platform: MT6737T Serial Number: RV8K70780SD Imei: 356098765432111 Unique Number: CQN0093B5C28F25 Connections: AT,MTP Battery Status: 4.34V (83%) Network Type: GSM SIM Status: ABSENT Knox Version: v30 Warranty Bit: 1 Security Patch: 2018-08-01 Data Encryption State: encrypted Preparing... Checking root. The phone is rooted by: 2.78:SUPERSU Checking current patchcert. Reading data. Be patient! Do NOT disconnect the phone! Restarting phone. Waiting for ADB connection. Be patient! Do NOT disconnect the phone! Patching certificate... The operation is in progress. Be patient! Do NOT disconnect the phone! After the phone starts, the signal strength indicator will be OFF and after a few seconds it will be ON again. You can check the status of the imei using: *#0011# The patchcert can be removed by repeating the process. If a new firmware is used, the patchcert process must be repeated. Succeeded. Successfully finished. Finished at local time: [02.11.20 12:51:31] |
02-11-2020, 14:36 | #2 (permalink) | |
Product Manager Join Date: Jul 2012 Location: EU
Member: 1787203 Status: Offline Thanks Meter: 23,786 | reply Hi, please re-flash your device with complete stock firmware (do not use any customized file). After it repeat the processes, and please use magiskroot instead of the 2.78:SUPERSU. Best regards Nicole Quote:
