10-09-2019, 13:49
#1 (permalink)
Member: 2102546
Thanks Meter: 480 | J730F U4 Oreo Root, Repair, Patch Done All-In-One Solution Thank you to chimera tool all procedure automated in just one click it was really a next generation tool. Salute the developer
Rooting... Quote:
Chimera Mobile Phone Utility version: 22.59.0754 @ 2019-10-09
Rooting phone started
Checking custom root image...
Downloading custom root image. Be patient! Do NOT disconnect the phone!
Checking downloaded image.
Present.
Rooting by custom image-based root method...
Switching to download mode.
Waiting for download mode.
Connecting.
SBL Info: Model: SM-J730F, Region: EUR, Provider: OPEN, PDA: J730FXXU4BSD5
Reading PIT from phone.
Flashing boot.img
Restarting phone.
Waiting for ADB connection. Be patient! Do NOT disconnect the phone!
Checking root state...
Rooted.
Disabling Knox. Be patient! Do NOT disconnect the phone!
Knox disabled.
Successfully finished.
Finished at local time: [10.09.19 15:26:38]
WorkID: 75662507
| Repair IMEI.. Quote:
Printing phone history
Root/Unroot
2019-mm-09
12:11:22
PM
Repair started
Gathering phone info...
Collecting information. Be patient! Do NOT disconnect the phone!
Model: SM-J730F
Sales Code: NEE
Country Code: Nordic
Timezone: Africa/Addis_Ababa
Android Version: 8.1.0 [M1AJQ] [SDK 27]
Build Date: Tue Apr 23 10:46:58 KST 2019
PDA Version: J730FXXU4BSD5 [april 2019, rev5]
Phone Version: J730FXXU4BSD5 [april 2019, rev5]
CSC Version: J730FNEE4BSD5 [april 2019, rev5]
Board Platform: EXYNOS5
Modem Platform: SHANNON315
Serial Number: RF8K81VXGRB
Imei: 358224094920380
Battery Status: 3.78V (10%)
Network Type: GSM
SIM Status: ABSENT,ABSENT
Multisim Config: DSDS
Knox Version: v30
Warranty Bit: 1
Security Patch: 2019-03-01
Data Encryption State: unencrypted
Repair imei...
Checking modem version.
Restarting phone.
Reading data. Be patient! Do NOT disconnect the phone!
Repaired IMEI: 355727097161128
Repaired IMEI2: 355727097161136
If necessary, use the patch cert procedure.
Succeeded.
Finished at local time: [10.09.19 15:29:41]
WorkID: 75664143
| Patching Cert... Quote:
Repair IMEI
2019-mm-09
12:28:11
PM
Root/Unroot
2019-mm-09
12:11:22
PM
Patch certificate started
Model: SM-J730F
Sales Code: NEE
Product Code: NEE
HIDSw Version: J730FXXU4BSD5/J730FNEE4BSD5/J730FXXU4BSD5/J730FXXU4BSD5
Imei: 355727097161128
Unique Number: CCK007B0DEE3D65
Connections: AT,MTP
Battery Status: 3.74V (10%)
Network Type: GSM
Knox Version: v30
Warranty Bit: 1
Preparing...
Checking current patchcert.
Restarting phone.
Previous patchcert successfully removed.
Checking modem.
Checking root.
The phone is rooted by: Chimera SU v1.0
Checking boot image. Be patient! Do NOT disconnect the phone!
Writing boot image.
Restarting phone.
Reading data...
Patching certificate...
The operation is in progress. Be patient! Do NOT disconnect the phone!
After the phone starts, it switches to flying mode and then returns to normal mode after 20-70 seconds.
You can check the status of the imei using: *#0011#
The patchcert can be removed by repeating the process.
If a new firmware is used, the patchcert process must be repeated.
Succeeded.
Finished at local time: [10.09.19 15:33:17]
WorkID: 75664417
| BR,
Baya |
